Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
1120 jazzy is jerking left side when you take off but after awhile it quits how do i fix
Posted by Carey Dell on
Mark Brown
    Filmmaker:
    Uploaded 5 video answers.
  • 168 Answers
Sounds like a loose wire / conector or you need new motor brushes.
Posted on Dec 02, 2013
2 Related Answers
Anonymous
SOURCE: Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Posted on Aug 28, 2009
lennieg2000
  • 692 Answers
SOURCE: what are the best batteries
andre Your Jazzy uses 2 Group 24 batteries and I would get MK batteries they are very good and can last 3-4 years if taken care of. Follow their charging recommendations and you should get great service from them Hope this helps you
Posted on Sep 18, 2010
Jazzy 1120
"Cuts out" is not enough info. Check all connections for tightness, full battery and light codes.
Apr 29, 2013 | Pride Mobility Products Used Jazzy...
I have a Jazzy 1120 When I turn it on all the battery lights flash rapidly any suggestions
How many are flashing? There are 10 lights, if all are flashing (3 red, 4 yellow, 3 green) that indicates Code 10 and high battery voltage.
Apr 03, 2013 | Pride Mobility Products Used Jazzy...
Jazzy 1120 changing controller type?
The 1120 usually comes with either of 3 different controllers: Pilot, Remote Plus or Europa. They function similarly but the setups are a bit different.
Apr 02, 2013 | Pride Mobility Products Used Jazzy...
If my battery failed on my 1120 jazzy chair can it be pushed maually to get home or not
There should be a lever on the back rear to put the device in neutral. On the other hand, gel cell batteries are generally available at auto parts stores. Why not just get two new ones and replace them if they are done for?
Just a thought.
Mar 19, 2011 | Pride Mobility Products Used Jazzy...
My hand controler on my jazzy 1120 2000 keeps blink and I can not get the chair to move the batteries are good
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Oct 05, 2010 | Pride Mobility Products Used Jazzy...
The joystick is not sensitive enough, there is a pause between the joystick movement and the motor response. Jazzy 1120 how to adjust it?
The Jazzy wheelchairs have programmable controller. This includes the length of the pause before moving, speed, acceleration speed and deacceleration speed. You usually need a programmer to change the programming. You supplier should have one. For your nearest supplier have a look at the pridemobility website: www.pridemobility.com
Apr 21, 2010 | Pride Mobility Products Used Jazzy...
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
93 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
