SOURCE: It is ok?
It is not a potential threat when you started getting this message after your installed the memory module but its annoying.I would suggest you to reset your bios setting and save and exit. If its still not working kindly revert back to me...
Thanks and Regards...
SOURCE: is normal this?
put the ram in the same colored slots,
ie both in black or both in yellow.
good luck
Terry
SOURCE: i have a compaq presaario
Press F12 right after you turn the computer on, this should give you boot options, select boot from CD, press OK and you may get a prompt displayed to "Press Enter To Boot From CD" You should be good to go from there. I hope this helps. Good luck and have a pleasent day.
SOURCE: hi my original problem of black screen turned out
Well... if your target is the motherboard replacement (and nothing else is going wrong except of your motherboard),
you don't need to reinstall the OS again (op hard disk).... if your new motherboard is axactly the same brand/model as the old one, nothing more you need to do, but only the to replace the old motherboard by the new one!!!
