My Magnavox cannot tune digital channels 7 through 13 but will tune them analog but snowy. I also have JVC and Panasonic recorders and a Philips Flat-screen hooked to the same 4 set splitter. All units tune in all channels both digitally and analog with a clear picture. I have tried rescanning all the channels several times and tried to manually tune them in, to no avail. Is this a common problem with these units? Any fix without sending it back? Thanks for any help.
SOURCE: I have a Magnavox h2160m9a
No,it is not necessary to return it..
As far as I explore it ,this feature is user adjustable ..Have you gone thru "user manual " ?
if you need a soft User Manual in PdF format I have a copy of " "..H2160MW9 HDD & DVD PLAYER / RECORDER WITH DIGITAL TUNER " *another version of yours..
if you like I can forward to you too..just give me your e mail..thats it..
Take care..Regards
SOURCE: I have hooked up my ZV427MG9 Magnavox DVD recorder
Hi, sometimes one also must hook up the Audio with the red & White audio stereo leads as well some HDMI do NOT stream the audio over the HDMI port, and thus one must use the RCA stereo jacks to supply audio to the device.
Some HDMI cables also don't have all the wires through and a change of cable may help, this is rare though.
SOURCE: I cannot record digital when I try to set up my
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
