Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
Question about Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player
Ipod touch will not switch on fully charged left on docking staton all day swiched off with docking station
It has been freezing a few times .working fine last night .left on docking station over night was charging when on docking station .will not swich on .total no power at all .please help it was a xmas pres for misses.many thanks kev
Posted by kev.turner on
Brian Sullivan
  • Apple Master
  • 27,725 Answers
How many times have you charged it
Ipod batteries have a lifespan so they can only be recharged a certain ammount of times before they need replacing
if it will turn on with a charger either your battery is completely dead or the battery connections are loose or faulty
hope this helps
Posted on Jan 03, 2012
1helpful
2answers
Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Lead to docking station dont work
contact the nearest apple store. in most cases they would replace this stuff because they want the apple name to keep flying high. Or you'll have to replace the entire docking station if the lead is not sold seperately.
14helpful
2answers
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
3answers
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
8helpful
2answers
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
3answers
i have the same problem with the old docks not charging my ipod touch and yes new bose docks and ihomes charge the 32g ipod touch
I200 not charging ipod touch
Hi yes the touch is too new for almost all docking stations as i have the same problem your best just charging it through the computer or the socket.
1helpful
3answers
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
14helpful
2answers
Speakers won't work when Ipod is docked
The problem is that Atlec Lansing used a low quality (piece of ****) plug/interface for the dock. If you pull the top of the ipod forward while it is pressed fully onto the docking station, you'll get a surprise. It will work. This problem stumped me for days. Now, the next question is how much tension is the proper amount not to degrade the cheap plug further or damage the ipod itself.
Cheers,
Jeff
6answers
Archos 605 wifi freezes
Mine kept freezing alot, and now the on/off button wont work. I can only turn it on with the docking station.
Top Apple Audio Players & Recorders Experts
woodzowl307
Marvin
Marvin
W.L.
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
