SOURCE: samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
SOURCE: phone does not detect headset
Put your headset in pairing mode first. Turn it off. Then, press and hold the MFB for some 8 seconds, until the indicator light is steady blue. Then, make your phone's bluetooth application search for new devices. Your headset should appear on the phone screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash rapidly 10 times, and enter the stand-by mode (light flashing every 3 seconds). The pairing procedure should be done only once. After any two devices are paired, just by bringing them within 10-feet from each other should suffice to have the bluetooth link done. Otherwise, a simple press on the MFB should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to pair your headset with your phone.
Regards,
Carlos
SOURCE: Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
SOURCE: Need driver for Samsung WEP450 bluetooth for
Since the device is Bluetooth you should not need any drivers. Make sure you have charged the earpiece fully, and that it is ready to connect (most of the time that is just a matter of holding in the lighted button until it blinks and then is solid once you stop holding it down). Then make sure bluetooth is set to discovery on your Windows device. Most times to do this you just need to enable bluetooth. You can do this from your control panel. Hope this helps. Have a great day.
Testimonial: "Thanks for the help. It worked!"
