The back of the dimmer has 1 black and red next to each other. The other red wire is by it self
SOURCE: Dimmer Switch Installation issue
ALL you really need to worry about is the white and black wire that you hooked up before. The green ground screw is not needed. If you have a bare wire completely bare all the way, you can hook it to the green, but it is not required to work.
The other 2 screws are for the switch. It does not matter which wire goes where, as the switch just puts them together, and takes them apart.
SOURCE: Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
SOURCE: Trying to install trimatron 120vac push dimmer
Called the guys at Home Depot and they helped me over the phone.
thanks
SOURCE: two slots on back of dimmer. one has single black
Yes, this is a single pole dimmer switch. Connect the green wire to the ground wire in your electrical switch box and connect one black wire to the power (common wire) in the switch box and the other to the wire going to the incandesant light fixture. (Standard dimmers cannot be used with CFL type bulbs).
You should be working fine! Remember to turn off the power to the wiring your connecting this dimmer to to prevent both getting a shock and from damaging the dimmer during installation.
Hope you found this very helpful and best regards!
SOURCE: how to wire 3 switches in a 3 gang box
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram:
