Please contact if anyone knows of anyone that has a broken garmin 198c plotter, that has all the pins in place on the back that i could buy off them. thankyou
SOURCE: Where can I buy spare parts?
http://www.gpsw.co.uk/cats/cl3_224.html try that one or ebay parts
SOURCE: Garmin eTrex legend Joystick not working
I had a similar problem with my first unit. I returned it to the store where I bought it, and they were kind enough to give me a new unit because it was still under warranty. Normally, it would have to be sent to Garmin for replacement under warranty. It might be worth a try if your unit is still under warranty.
SOURCE: Garmin C530 need pin to unlock
Have you tried putting the unlock code in the main directory? To do this open up notepad or some similar text program and copy the code from the yellow sheet onto the note pad and save it as GMAPPROM.UNL. Then open "My Computer" and locate the Garmin removable device. Open the "Garmin" folder and copy that file to it. Safely remove it from your system and turn it on.
SOURCE: I purchased a used locked Garmin c530 gps
you will have to ask the previous owner for the lock code. if he doesn't know it, get you money back from him. the only way to unlock a garmin is to know which location the code was first programmed in or by sending it back to garmin with proof of purchase. this is an anti-theft feature.
SOURCE: need factory default for a garmin streetpilot c550 gps or pin unlock code?
There is no factory default unlock PIN code. You will need to take the unit back to your security location and it will automatically unlock.
Does anyone no how long you are covered for on your warranty when you purchase a garminplotter
Do you no how long the warranty lasts for. I'm really struggling to get it fixed . I've found someone that can fix it for me but I need the part, I need to get lucky and find someone that has one for spares, or hope that someone can come up with a company that stocks this component.
