It was a new printer that came with its cartridges,so, i was out of ink and wanted to refill it, therefore, it says that the following ink tank can not be recognized?
SOURCE: MP500 ink tank cannot be recognized error U043
I had the same problem with a Canon Pixma MP800 here is the procedure I went through to fix it. I removed the new cartridge then taking a clean tissue I gently wiped the front of the ink well were the the electronic chip in the cartridge meets the ink head. I replaced the new ink cartridge and the red light came on. I closed the cover the printer returned to normal working mode!
SOURCE: refilling of canon ink fine cartridge pg 41
reset the cartridge from the printer. there are a few steps to follow
SOURCE: x5470 Lexmark printer
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
SOURCE: The following ink has run out
Press and hold stop/reset for 5 seconds to disable the function. Printer should now print
SOURCE: Printer will not recognize refilled black HP cartridge (#74)
Try to get your printer to recognize the new cartridge; go to start -
printer and faxes -right click on printer - preferences (printing
preferences) -settings -load factory settings. Print test page Ctrl+P
Please post if that worked.
Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
