2004 Nissan Armada Logo
Posted on Oct 06, 2008
Nissan primera gearbox
Could you please tell me if the gearbox from a 1998nissan primera 20ltr gt will fit a 1998 nissan primera 20ltr gx estate many thanks kev ward..
  • 1 more comment
  • Anonymous Mar 18, 2014
    door handle won't work on 1992 Nissan Primera
  • Anonymous Mar 27, 2014
    NISSAN PRIMERA 2002HOW DO YOU REMOVE CONSOL
  • Anonymous Mar 31, 2014
    how do i find bolts to remove starter motor
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1796
Points
9
How much is the price for nissan primera 2003 gear box
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1970
Points
My nissan primera 2002 has a hard start, what is the cause?
Nissan Primera Automatic will not reverse normaly but in difficult,
Hey there i have a 1996 nissan primera 4wd auto every gears works mint as no issues its fool with gearbox oil but it wont drive in reverse what would you recommend? Would it be tge reverse sencor?
7helpful
Nissan primera, engine management light permanently on. When car is first started gearbox changes without a problem. when the engine gets warm it sticks in 1st or sticks in 3rd and 4th and won't change...
Hi Kev,
Your Nissan Primera has an on-board diagnostic computer which can detect malfunctions in either engine or transmission.
When the Engine Management light remains lit, this means some faults are present and need investigating.
From what you've described, one of the issues is indeed related to the transmission, but you will need to have the trouble codes (DTC's) extracted from your vehicle's computer, in order to determine what requires repair.
Whenever power is disconnected (i.e. the battery) and re-connected, this resets your vehicle's computer momentarily, until such time as it detects the fault again.
Recommend you either have your local dealer extract the codes (for a small 15min labor fee), or learn to extract the codes yourself, using a suitable jumper wire.
"If this has helped you in any way, please rate this solution"
Regards,
1helpful
I have a nissan almera 2001 1500 what model
hi i am not 100% sure but i think it is the P11 144 gearbox its used with the almera qg15de engine. i think it is also used in a primera and almera tino of the same years.
How to fit air filter, in nissan primera
i have a leak on my oil filter ive justchangedit the wasnta leak before i did ive tried2 filters still the same could you tell me the correct way to fit thisits the paper filter and rubber o seal
4helpful
I have a 98 nissan primera sri with the factory fitted nats alarm/immobiliser.the mil light is flashing on the instrument panel and the alarm indication light is on when i turn on the ignition.the engine...
your nissan primera nats alarm is connected to the factory fitted stereo. check your stereo fuse as these are the symtoms i have done this before
1helpful
2answers
REPLACE C V JOINT ON NISSAN PRIMERA 1998
you will have to loosen the center nut that is located on the front hub while the care is still down on the ground to make it easy to undo then jack the car up and put it on a car stand then loosen the 6 locating nuts and bolts on the gearbox flange if it dosent have the bolts and flange it requires to use 2 leavers on both sides of the iner c v joint and pop the c v out before you try to pop the c v out you must undo the bottom lower control arm so that you can move it free if you dont undo control arm it will keep the c v sold against the fron wheel hub
Sideskirts
Most likely. If the bodys the same it should. usually the differences are minimal, you may have to do some custome fitting but nothing too hard.
Just plan and use good judgement.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
