Question about Kaz Humidifiers
Honeywell humidifier model HCM-305T-CST. when running it sounds like something is interfering with the fan
The unit has been cleaned and new filter inserted. When on the fan makes a noise as if there is something hitting it or rubbing the blades
1 Related Answer
Anonymous
SOURCE: where is on/off switch HCM-305T-CST
There is a 0 setting on the fan speed setting knob ...
Posted on Jan 05, 2009
No humidity
remove and clean the filter then re-install it the air is being blocked
Dec 03, 2013 | Honeywell QuietCare HCM-630 Humidifier
Should anything be done to 305t before it retires for the summer?
Yes, there is. Routine maintenance is important. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank with it. Run the humidifier until the tank is 1/2 empty. Then empty the remaining solution and refill the tank 1/2 way with Bottled Distilled Water and run it until it's empty. This will flush the entire system of the previous 50/50 solution. If you can access the fresh air intake, clean that using a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the accumulated dust. Be sure the unit is completely dry before storing it.
If more folks would do this, they wouldn't have problems in the Fall & Winter.
Apr 12, 2011 | Honeywell HCM-300T Humidifier
My Quietcare portable humidifier isn't working anymore after I cleaned the inside. The orange light is on but no fan is running. What is the problem and how do I fix it?
I was having the same issue. I noticed that when the main fan unit was removed, there was a small plastic piece that was sticking up from the base next to the filter, which has a female end on the fan unit. I played with this, and realized I could lift it up. Once I did this, I replaced the fan unit and it started working. I think this is the water level reader which, when all the way down, won't allow the fan to start since it thinks there is no water.
Dec 20, 2010 | Honeywell QuietCare HCM-630 Humidifier
Honeywell HCM-646 -Motor not running
There is normally a capacitor to prevent surges across the motor it might the short circuit.# and preventing the motor from starting.
Jan 13, 2018 | Honeywell HCM-646 4 Gallon Humidifier
Humidistat problems
The ability of the humidifier to maintain a given moisture content in the air is far more difficult than a heat or cooling unit to heat or cool the air.
Moisture vapor has far more energy to seek dryer air, than tempered air. So the moisture seeks and finds dryer air quickly, whether it be through stair and door ways, or through cracks and seams in walls and doors/windows, or through non vapor barrier surfaces.
The only way the unit would be able to achieve a humidity level as stated, is for the unit to be placed in a vapor-tite room that has a minimal of leakage.
You could put more humidifiers in the space, or more and larger humidifiers in the space, to try and overcome the vapor moving to other areas of the space. But unless you have a fairly vaportite space, it is unlikely the unit is under capacity, and the only way to test what capacity is needed is to take humidity measurements.
Reply back with any questions you may have.
Feb 03, 2009 | Honeywell HCM-300T Humidifier
Honeywell HCM-305T Spits droplets rather than creating a mist.
Thanks for your question,
Sounds to me like you have something partially cloging the misting nozzle, if you can take the nozzle off, and check it I would bet there is something that got in there, if you cant, it might be better to just return the Humidifier where purchased for an exchange, if you can get the nozzle off, if you have a can of compressed air like they sell for dusting off computers, I would use a very short burst of that in the nozzle, and in the feed line, thanks again for your question, let me know how it works out,
mr.grzz
Jan 14, 2009 | Honeywell HCM-300T Humidifier
Where is on/off switch HCM-305T-CST
Dec 20, 2008 | Honeywell : Cool Moisture Humidifier...
Humidifiers Logo
62 people viewed this question
Top Kaz Humidifiers Experts
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
