Question about KitchenAid Architect® KUDT03FT 24 in Builtin Dishwasher
Dishwasher just keeps washing, it doesn't stop or attempt to cycle forward
I've cancelled the current cycle and tried to start a different cycle. Nothing happens initially when I close the door but after a bit it starts washing again and never drains or changes cycle
Posted by skh96 on
hkapptech
    New Friend:
  • 183 Answers
Cycle can take 2 hrs to complete. give it time,
Posted on Jan 03, 2012
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
My gaggenau dishwasher GM 954-110 is not working. when i switch it on the display panel shows 2H.
Hello, welcome to FixYa.
The dishwasher you're speaking of (provided it is indeed a Gaggenau GM954) is built by Bosch as you may or may not know.
To address your concern regarding the 2H in the display actually needs to be done in two parts. I'll start with the basic info associated with the 2H displayed.
This can be simply indicating the previous cycle exceeded a 2 hour wash cycle, not necessarily an error and can be attributed with too cold water entering the dishwasher (below the recommended 120F), a longer than normal drain time (due to partial blockages, kink etc. hence longer time needed to complete the cycle) or inproper water circulation during the cycle.
Aside from these issues, it (2H) can also mean the unit has a heating error and if left long enough will show another error of "1" in the display, extremely long wash times, etc.
**The first thing I'd suggest before attempting any repair is running an additional cycle while making sure the water inlet is hot (120F optimum) and the unit does indeed drain fine.
**A fair indication of proper draining is to start a cycle and once washing begins (2-3 minutes) activate the "cancel" and the unit should adequately drain in the 2 minute time allowance.
**To identify proper water circulation, place an empty cup in the upright position in the top rack, start a cycle and inspect the cup after 2-3 minutes and it should be full of water.
After trying and posting the results of these thing's we can move forward with potential heating errors, the cause, and how to remedy them. Let me know what you find and I'll continue to assist you in any manner possible going forward. Good luck.
Regards,
Macmarkus :)
Jun 30, 2011 | Dishwashers
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid Architect® KUDT03FT 24 in Builtin Dishwasher Logo
642 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
