Yes. If you change the password of the wireless network then other 2 units will get disconnected from wireless network (if they are connected to the wireless network. If these 2 units are wired to the router then it does not make any change)
I will suggest you to change the wireless network name also if you are changing the wireless network password.
Try to connect to the new wireless network on all the computers and devices.
Linksys router how to
SOURCE: reset and setup help on dynex dx-wgrtr wrireless g router
Hi guys, I have the same router and I had the same issue. I just figured out how to fix it. All you have to do is access the mac ip address and it will give you all of the information that you need. It will show you your old password (which you can reset if you want), also it lets you access all of the settings on the Dynex router. The mac (ip) address for this router is http://192.168.2.1/. I recomend righting this (along with your password) on the router itself with a sharpy (marker) so that you can find it quickly in the future if you have the same problem. Godd luck, I hope this helps you.
SOURCE: I use a netgearDG834g router. I need to adjust the
If you reset your router you will need to reconfigure all the setting, like broadband username and password, as well as wep/wpa/tkip keys for wireless security. Once this is all done you need to allow the port through the firewall, but you have to specify the destination ip address of the XBox as server address in the inbound rule of the firewall. It will then do a port address translation from outside ip address to inside XBox address only for traffic destined to that port specified in the firewall entry.
SOURCE: Can I retrieve the current
Yes-
Open INTERNET EXPLORER and. In the URL address field, enter the IP address for your wireless router ( the DEFAULT GATEWAY). This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for password.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.
