Goodyear GY500X Car GPS Receiver Logo
marvin fountain Posted on Jan 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set the time on goodyear gy500x
There is no time displayed how do i get the actual time to show
Richard Roth
Level 3:
Top Expert:
  • Master 9,472 Answers
  • Posted on Jan 02, 2012
Richard Roth
Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626584
Points
28464
You will need to go into the setup menu to enable this feature. If you need a user manual please let me know and I will locate one for you.
2answers
Ferrari World Time watch setting, manual is awful and useless
You have to hold down B to set up T1 which is the time the hands will display. Once you see the City and T1 show up on the digital display you can go through the various settings to set time/date etc. Use B to cycle through setup and A to make the necessary changes.
Pushing the crown allows you to set up T2 or the time displayed on the digital section. You set this by choosing the time zone.
Hope this helps
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
How do rubber hoses function to make sure proper industrial function ?
Hoses are one of the most essential and important part of mega machines and factories and they are keeping the temperature down by flowing the hottest liquids of all the time. For this hose Goodyear is one of the apt one for the machineries. Click Here : Home FDJohnson
2answers
1964 chevy c20 backfires through carbrator
That is a mechanical timing issue with the crank and the cam. IF the engine has a lot of miles on it, you may need to overhaul the timing gears and chain. If you rebuilt it, the timing is not right.
1helpful
Where do I go to get map data updates for the Goodyear GY120 GPS syatem.
This GPS does not currently have updates available.
http://www.thencc.com/goodyear/gy120.html this website will allow you to check on updates but there is no scheduled time that they will be updated.
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 • Vacuums
1helpful
2003 GMC Envoy noisy steering box 80000 miles
Sounds like the Goodyear by you is a bunch of idiots make an appointment with your locale GMC dealership they usually diagnose for free.
1helpful
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
3helpful
4answers
How to change the time on screen
generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Setting the right time
Check page 164 of the manual, you can set it as below:
Top Goodyear GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Goodyear GPS Expert? Answer questions, earn points and help others
