I need in driver for Win7 for camcoder vdr-d300 to use coonnection with PC
SOURCE: USB connection is not recognised by computer
the camcorder must be connected to the mains adaptor to power the usb socket
SOURCE: Camcorder Problem
You need to do formatting on the disc when using it for the first time. Remember, formatting needs to be done by camcorder. If you used the disc before and formatted it on different machine - it won't work.
SOURCE: Cannot finalize disc
I discovered a solution to the finalizing issue and perhaps it is the same for you. It turns out the disc I have (I think that came with the camera) is a DVD-RAM and these do not need to be finalized. I just went straight to the DVD Movie Album downloaded from the set up disc and it downloaded. Hope that helps.
SOURCE: change mode to use usb
reading the manual, you will need to install all the software before it will be recognised on a Mac - see page 130 onwards
Page 137 goes through the USB connection
Testimonial: "Thanks for that. I was looking for 3 hours for a solution so this has really made my day :) cyao JEDI"
