Question about Braun Health & Beauty
Ear thermometer 6022 is reading PO5 instead of temperatures how do you fix it
When taking temp it beeps like its done then it reads PO5
mahi
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
1 Related Answer
Anonymous
  • 8 Answers
SOURCE: We have the Braun 6022
If you whish to switch from Celsius to Fahrenheit, proceed as follows:
(1) Make sure the thermometer is turned off.
(2) Press and hold down the Start button (IRT 4020)
or the «I/O» button (IRT 4520). After about
3 seconds the display will show this sequence:
«°F» / «SET» / «°C» / «SET» ...
(3) Release the Start button / «I/O» button when the
desired temperature scale is shown. There will be
a short beep to confirm the new setting, then the
thermometer is turned off automatically.
Posted on Mar 17, 2011
Braun thermoscan 6022
It's probable that it needs a new lens filter or the filter needs cleaning. I have no idea how to remove the filter but it probably clips or screws off the bit that goes in the ear.
Quite frankly the device is at best unreliable, it measures infra-red in the ear, great in theory but not very reliable in practice. I would use a different thermometer.
May 15, 2014 | Home
User manual mf-16
You probably won't find it. Insert in ear, press button, wait for beep, read temp.
Jan 07, 2013 | Mark Of Fitness MF 16 Ear Thermometer
I don't have the directions how do I work it i have ThermoScan and want to use on 4month old
How to use Braun ThermoScan 1. Always make sure a new, clean lens filter is in place to help ensure an accurate reading. The thermometer will not function without a lens filter attached (see Changing the lens filter). 2. Press the /mem button. The LCD (liquid crystal display) is activated, showing all segments. When the ready symbol is displayed the thermometer is ready for use. 6 To help ensure an accurate temperature reading, use the following technique: If you are right handed, hold the thermometer in the right hand and take the temperature in the right ear. If you are left handed, hold it in the left hand and use the left ear. 3. Perform an ear tug to straighten the ear canal. This gives the thermometer a clear view of the eardrum. Children under 1 year: Pull the ear straight back. Children aged 1 year to adult: Pull the ear up and back. An ear tug is best performed by using your free hand to grasp the outer edge of the top half of the ear. To take your own temperature, wrap your free hand around the back of your head and grab your ear from behind. 4. While tugging the ear, fit the probe snugly into the ear canal as far as possible and press the activation button. Release it when you hear a beep. This is the Temp Beep that confirms the end of measurement. 5. Remove the thermometer from the ear canal. The LCD displays the temperature measured. 6. Replace the lens filter after each measurement: press the ejector button and put on a new, clean lens filter. 7. A new measurement can be taken as long as the ready symbol is shown. If no button is pressed within 2 minutes, the thermometer will turn off automatically. 7 Note: In the following situations, it is recommended that you take three temperatures in the same ear. If they differ, use the highest reading. · Infants in the first 90 days of life. · Children under three years of age who have a condition such as a compromised immune system and for whom the presence or absence of fever is critical. · When you are first learning to use the ear thermometer until you are comfortable with the technique and are obtaining consistent readings. Important: As with any type of thermometer, slight temperature variations ( ± 0.3 - 0.5 °F / ± 0.2 - 0.3 °C) can occur, if consecutive measurements are taken. Temperature taking hints · The right ear reading may differ from the reading taken at the left ear. Therefore, always take the temperature in the same ear. · The ear must be free from obstructions or excess earwax buildup to take an accurate reading. · External factors may influence ear temperatures, including when an individual has: - been lying on one ear or the other - had their ears covered - been exposed to very hot or very cold temperatures, or - been recently swimming or bathing. In these cases, remove the individual from the situation and wait 20 minutes prior to taking a temperature.
Mar 04, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
We have the Braun 6022 thermometer. It is reading in C so temps are coming up (ex. 37.1 C) how do we get it back to F
Mar 04, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Feb 28, 2011 | Braun Health & Beauty
I have a Braun thermoscan type 6022, but code po5 always comes up. What does that mean?
It's not po5, its pos... you're not positioning it properly in the ear canal.
Jan 26, 2011 | Braun Health & Beauty
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    Health & Beauty Logo
    2,040 people viewed this question
    Top Braun Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Marvin
    Marvin
    Michael Thomas
    Michael Thomas
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
