SOURCE: "Memory Low, Delete Some Data"
You might want to try a "Hard-Reset" To do this you turn of your phone, press and hold "Answer Call(Green)"+"3"+"*" and then turn it on. This should reset your phone completely and clear the memory. CAUTION, back up all your vital data before you do this, it clears EVERYTHING.
SOURCE: Phone Memory Doesn't Increase Even If I delete messages
Something probably got stuck in your phones memory, the easy way to solve this is to backup your contacts, calendar and other important items to your computer and do a hard reset of your phone., This is achieved by turning the phone off, press " 3 ", " * " and " green (answer call) " and turning the phone on at the same time. Remember to save anything valuable, because it clears EVERYTHING.
SOURCE: NOT ENOUGH MEMORY TO PERFORM OPERATION.DELETE SOME DATA FIRST"
I think you installed the virus in phone. You need to hard reset your phone. Back up your data on your phone e.g. contacts, tones, images and videos.
WARNING ALL DATA ON YOUR PHONE WILL BE ERASE.
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see the hand animation is displayed.
SOURCE: Big Problem Sending & Recieving Messages
I am assuming that you purchased this as an unlocked phone?
It needs to be set up with your carrier if you already have not.
If you did a full reset, the settings for your carrier most likely were not retained through the reset.
The reason you would get this message on your phone would be if the messaging is not set up properly, it will try to use other resources on your phone not meant for messaging.
If your on T-Mobile, go to
http://tmobileuspublic.wdsglobal.com/
and follow the instructions to set up messaging and web.
If your on AT&T Wireless, go to
http://selfcare.mycingular.net:8082/scgui/
Hope this helps,
Simon.
SOURCE: transfer files into memory card
Please follow the below steps:
Open Messaging -> Options -> Settings -> Others -> Memory In Use.
Then change memory in use to memory card and files that you received will be save in the memory card
