Hi. I have a celestial split system air conditioner and it blows out cold air off and on now. it cuts out a lot and blows out warm stinky air and then after a bit it goes cold again. It didn’t do that brand new and it does it quite a bit. Its really annoying and it doesn’t cool the house very good anymore. I would appreciate any advice on what the problem might be. Thanks for your help. Jeremy. my email is [email protected]
SOURCE: Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
TRY TO SHUT DOWN THE BREAK AND TURN IT ON AGAIN 10 MIN LATER
the problem is when i want to cool the room not heat it. its not on the wrong setting
