Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
How to discale the unit - DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Posted by Martin Beglinger on
Nick Metcalfe
    New Friend:
  • 30 Answers
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Posted on Jan 28, 2012
How to clean a qyo214a manitowoc ice machine
cleaning manitowoc ice machine video. discale
May 15, 2014 | Refrigerators
Machine seys to discale.. But when we tray to do so it won't even brew with the winegar .When The
You need factory service unless you can disassemble it yourself to clean it. Start with the piercing unit.
Aug 25, 2012 | Keurig B70 Platinum Brewing System B-70
Will not fill with water, partially filled a few days ago
can be that the water valve it's restricted with scale, if you want to clean it deep it into discaler, or vinegar for an hour or so, or replace it, you will find it, at the end of the water hose under the D/W.
Jan 06, 2010 | Asko Dishwashers
Need solution to fix this problem where i can buy discaling solution?
its avilable only in siemens company,no other soultion work
Jul 09, 2009 | Espressione Caf? Dolce Aroma
How do i clean the pump for the delonghi ec702?
you have t use a discaller for expresso machine not vinergar not strong enought follow the instruction on the discaller put product inthe machine with the water start the the machine after a few second turn it off for 10 minute time for the discaller to work repeat untill empty rinse very good that it do that every 3 month thanks pierre
Dec 13, 2008 | DeLonghi EC701 Espresso Machine
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
556 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Jeffrey Groves
Jeffrey Groves
Charles Tidwell
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
