Kodak EasyShare M853 memory card has been plugged into my computer. What is next step to import photos?
.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
SOURCE: I have Z612 Kodak Easyshare
I had the same problem when I bought a 4GB card to replace the original 2GB. When I took it back to BestBuy where I bought the camera, I was told that this camera could only use a 2GB card. So, I bought a 2GB card, installed it, and everything was fine.
SOURCE: Self Repair Cracked LCD
I just replaced the LCD in my Kodak EasyShare753. I removed all of the screws that I could find, but still couldn't get the case apart. I finally found that the selector knob on the top of the camera has to be rotated to the SCN position. The lower part of the knob is slotted so that the camera case easily slides apart once the slot is pointing in the right direction.
SOURCE: Kodak Easyshare C533
This means that the internal memory of the camera is full. Apart from the external memory slot, camera's have this what you call internal memory. It is built-in to the unit itself.
What you want to do is to set the default storage to the external memory instead of the internal once.
On the Menu, navigate to image store and then choose AUTO.
Auto (default)—the camera uses the card if one is in the
camera. If not, the camera uses internal memory.
Internal Memory—the camera uses internal memory,
even if a card is installed.
Also, you would want to set the camera resolution to a lower value to. The higher the pixel rate, the bigger space it eats up in your memory storage.
