Question about Lexmark X4270 All-In-One InkJet Printer
Need paper work on hoe to use my fax machine
I need to print paper work on my fax machine.the type of machine isan x4270 can you please help do this?
Posted by amy rivas on
Lexmark
  • Official Brand Answer
  • 3,344 Answers
Please visit the Lexmark website for the Lexmark X4270 User's Guide. This contains detailed instructions on how to use your printer's features and functions.
I hope this helps.
Posted on Jan 02, 2012
4 Related Answers
Geraldine Watts
  • 390 Answers
SOURCE: blurry printing fro lexmark x4270
May be too much info blocking up print memory. Before printing off sites, make sure you clear print queue and slect printer friendly versions. Check to see if your printer has a work online or offline setting in preferences too.
Posted on Feb 14, 2008
IQUIT
  • 3940 Answers
SOURCE: lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Posted on Jul 14, 2008
Anonymous
  • 234 Answers
SOURCE: Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Posted on Aug 28, 2008
Anonymous
  • 77 Answers
SOURCE: lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Posted on Apr 27, 2009
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Need help on lexmark x 4270
To whiom it may concern my printer wont allow me to fax or copy do to it saying paper jam,so I cleared the jam and made sure that nothing is in it but it keep saying paper jam and will not allow me to fax or copy. Can you kindly help me with this problem please.
Oct 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper jams in Lexmark X4270
Mine is doing the exact same thing and I need to know how to fix it, I am expecting some very important paperwork and I need the fax machine working!
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 all in one
try cleaning the scanner glass it might have dirt settled on it.Had a similiar problem solved by cleaning it.
Jul 02, 2008 | Lexmark X4270 All-in-One Multifunction...
X4270 fax, printer machine
pls check the no is it correct or not and see the all the buttons of no are working fine .bye
Oct 01, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 Plain Paper Inkjet Fax Troubleshooting Forum
Goto the Lexmark site and get the right driver. make sure you have the right model fax and operating system. This appears to be the wrong printer driver.
Aug 02, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
