Question about Whirlpool 30 in.GJC3054 Electric Cooktop
My whirlpool gold cooktop has the control lock button lit up- i can't turn on any buners?
Posted by Andrea Menges on
Michael Thomas
  • Whirlpool Master
  • 3,056 Answers
Hello there and welcome to fixya
This is a fairly common issue with these
These cooktops have a internal memory built into them and if they get locked they need to be reset
SO what you will need to do is to unplug the power to the cooktop and leave it sit for 1 hr and do not touch ok then after the hour is up tunr on the power to the cooktop you may hear a audiable beep sound or a click sound this is normal now press the cancel button and you should be all right from here but if not please post me back a comment and tell me what is going on and i will give you further troubleshooting steps ok ?
Best regards Mike
Posted on Dec 31, 2011
How do I unlock my Dacor cooktop
When your Dacor cooktop is locked, there will be a red light lit above the Dacor emblem located under your cooktop controls.
If you see this light, pressing the Dacor emblem for three seconds will turn it off and unlock your range. Pressing it again for three seconds will again lock your range and turn the light back on.
Another fun thing about that Dacor emblem is that if one or more of your elements are lit, tapping it twice in quick succession will turn off all elements.
Sep 04, 2011 | Dacor Millennia ETT304 Electric Cooktop
The control knob for one of the buners on the left side won't turn and the other left side buner is very hard to turn. this has been the same since it was installed,
Hi
If the problem started since it was installed then it can be that its either a manufacturing defect or the installation is not correctly done. You can also try to blow air on the knobs to check if dirt is stopping it from working....Hope this helps...please post back for further assistance.
Daniel
Feb 15, 2011 | Capital Cooking PSCT364GN Stainless Steel...
We have a whirlpool gas cooktop, Model SC8720EDB, Serial FMG1005626. When the left two side burners are lit, either one or both, the suction fan automatically cuts on. When the right side burners are...
It does this by design. It is a safety feature on this model because it was designed to have a gill module on the left side. I don't know if you can change it without replacing the two left control valves with valves like it has on the right burners.
Nov 24, 2010 | Whirlpool 30 in. SC8720 Gas Cooktop
I have a Whirlpool Gold electric cooktop. It is
It sounds like the selector switch is shorted, the only way to fix that is to replace the switch
always unplug electricity before working on any electrical appliance
Sep 25, 2017 | Whirlpool GJC3034 Electric Cooktop
Can't turn on KECC508 cooktop I didn't buy it and it is in the house and the light in the middle to power all burners off is lit.
The middle light is the lock. You must hold it down for at least 7 seconds to unlock it, then the middle light will go off. Your hands can't be wet, or none of the buttons on mine work right.
Dec 17, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
New Whirlpool Cooktop Problem...Maybe.
The function 3 element are normal / depend to the intensity adjustment / the small 4th element are set for pre heating w/out burning , try to sdjust in lower adjusment or ann switch for pre heating.
Dec 04, 2007 | Cooktops
Whirlpool 30 in.GJC3054 Electric Cooktop Logo
316 people viewed this question
Top Whirlpool Cooktops Experts
Michael Thomas
Michael Thomas
Gustavo Ortiz
Gustavo Ortiz
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
