A firmware update addresses printhead error problem on recent Lexmark printers. Please visit the Lexmark website to download and install the Lexmark Firmware
Update . Select your corresponding model to start the download.
Should the error continue to display on your printer, please contact Lexmark Technical Support Center for further assistance.
SOURCE: check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
SOURCE: New Printer - Issue with installing printhead
first of all.. make sure that you remove the packing material from the cart or print heads and put them in properly.
then also if it it gives the same probem then try it with the old print heads.. if it doesnt gives any eror with the old ones then replace the new ones..
new ones are bad..
return them to store
SOURCE: 107.08 service printhead error
this error means the printer has lost communication with the scanner. lexmark says some surge protectors can cause this error also static discharge near the printer if you cannot clear this error by powering the machine off with it plugged into a grounded wall socket return it to where you bought it as an out of box failure
Testimonial: "thanks ... will need to return!"
SOURCE: Switch Printer off,check printhead type path (2).
it seems like there is no oil on the slide bar
