Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Poured water in my delonghi magnifica beans hopper.
I think my machine is a little older than this, but its a Delonghi Magnifica. Husband accidentally poured water where the beans go (through the burr grinder). Now it doesn't work. The grinder is spinning, but beans arent going through. Emptied the hopper, can see the burrs moving, but it won't grind beans.
Posted by Erica Heintz on
DEBORAH
    New Friend:
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Posted on Mar 12, 2012
Nick Metcalfe
    New Friend:
  • 30 Answers
Don't feel too bad, happens all the time. The grounds have dried to concrete and blocked up the grinder. If you or your husband are intrepid you might try removing the grinder assembly and chiseling it all out but usually a replacement grinder assembly is required to restore good performance. Low level of difficulty to replace.
Posted on Jan 28, 2012
5 Related Answers
Anonymous
  • 544 Answers
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Posted on Mar 21, 2009
Adam Peake
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
Anonymous
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
Anonymous
SOURCE: My Delonghi Magnifica (manual not digital) won't
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Posted on Aug 30, 2010
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: DeLonghi Esclusivo Magnifica grinder cogs
u need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Posted on Feb 28, 2011
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Grinding makes a lot of scratch noise and coffee wouldn't drip. The machine says to fill the beans but container is full.
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 27, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Doesnt gring the beans
More info please - makes a clacking noise? Anybody pour water in the beans?
Aug 24, 2011 | DeLonghi Magnifica 3300 Espresso Machine
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I cleaned my delonghi magnifica and now nothing works. neither water or coffee comes out.it is just out of warranty unfortunately. help!
have u switch it on on back cover ??? ummm make sure u have the bucket sat in correctly .....and tray is in properly... have you snapped off the peg on the rear of the bucket for wast ?? its located rear of bucket. bsc appliances bristol 07779933829 postal service too.
Feb 08, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have descaled and cleaned all parts of my delonghi Magnifica machine. The coffe beans are high quality and I have tried all levels of grinds. The coffee is extremely bitter and I can't think of any other...
Sorry to read about your problem, I hope this helps you out.
run some more fresh water thru the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Attemps to gind but no beans seem to get through Then the display indicates 'add beans' although it is full
Machine thinks there are no beans because it is not grinding. Most likely the grinder is blocked. The common causes are a small foreign object, a stale hard bean and moisture (either from water spillage or moist beans). The first thing you should do is vacuum ALL the beans out, set it to the coarsest grind setting and run the grinder a few times ( with no beans). Then put a small amount of fresh beans (make sure they are dry and not from fridge or freezer) in and try again. Give it a few goes. If it still wont grind have a good look down there, if it looks wet let it dry out for a while and try again. If none of thes easy tips help you will have to remove the top grinder burr and clean both burrs. Good luck.
Dec 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Accidentally put water in the Bean Bin
Husband says not good. If you're lucky the water will just drip away, but it's likely that the water has gotten into the grinder mechanism. It could get all gummed up, but worse still, it could get into the motor and short the motor out.
It's very fiddly to undo. You could leave out in the sun to dry out with the doors open, but he recommends (for safety reasons) to take the unit to a De'Longhi Service Center.
Refer to www.delonghi.com and select your country/region at the bottom of the page.
May 24, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
1,876 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Jeffrey Groves
Jeffrey Groves
Charles Tidwell
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
