Question about PfaFF Creative 7570
My machine sounds too, change the coals of the engine, and tighten strap sewn but still noisy.
At the machine she had stuck the wire in the engine started to sound really bad and I opened it, pull the thread and I also thought that the coals from the engine. was spent. the change and began to work better but did not have that noise. and by placing the engine started to sound bad again the machine, I do not know what else to do. Thank you for your help.
4 Suggested Answers
SewTechWayne
SewTechWayne
  • 186 Answers
SOURCE: main motor jammed due to stuck bobbin threads
If you are unable to get any stitches at all then it could be your hook basket has spun out of position and it needs to go to a repair shop.
Hopefully it is just a matter of cleaning out the upper tension discs from any lint or thread that is in there. (Make sure the presser foot is up when threading so the discs are open and the thread gets down into them completly and that the tension dial is not set too low or on zero).
I hope this helps, good luck!
Posted on Jan 31, 2009
SOURCE: Thread loops noted on underside of sewn fabric.
change the needle
clean under the needle plate where the feed dogs are for lint
also clean the bobbin area for lint & loose threads
Posted on Nov 22, 2010
Rick Martinez
  • 111 Answers
SOURCE: Last year I changed the machine engine (PfaFF 1222
If the machine did sew fast the the replacement motor, then the problem might be that the machine is getting gummed up somewhere. Pull off the top cover, remove the 5 screws from the bottom of the base plate, (4 large screws, 1 small screw), remove the base plate remove the 1 screw from the bottom of the free arm cover. Now you can see most of the moving parts. Spray a little WD 40 on all the areas that you see metal to metal rubbing together, both on the bottom side of the machine and the top side. Don't flood the machine and stay away from the motor area. Plug the machine in, lay it on it's back and run it full speed, or at least till it runs full speed. After you free it up, blow out the machine with compressed air, and reoil with tri flow all the areas again. Run the machine again, and you've started your own tail gate repair shop.
Posted on May 07, 2011
raj somaiya
  • 5370 Answers
SOURCE: I have sewn on my
Bobbin thread being too loose is due to two possible factors. The upper thread may be too loose allowing the bobbin thread to pull it under the fabric, or the upper thread may be too tight in which the bobbin thread will pull up to the top. Try adjusting the top tension to see if you can correct it. If it doesn't fix the problem, take out the bobbin and look for a screw on the bobbin case. If your bobbin case comes out from the underside of your machine, the screw is on the side. If yours is a drop in bobbin, it will usually be under the faceplate so you might have to take that off too to get to it. Turn the screw clockwise to tighten the bobbin, counterclockwise to loosen it. Only go a quarter of a turn at a time so you won't overshoot the mark.Then try by re-threading and sewing. The basic procedure for threading is as follows:---------- Note that Pfaff sewing machines thread from left to right, not right to left like other sewing machines. The upper tension discs should be raised at their highest position while threading, and the presser foot should be raised up until you thread the needle. Drop the presser foot right before you thread the needle. The prevents thread problems during use.-------------
  • Insert a full bobbin and retrieve the bobbin thread through the thread plate. Raise your sewing foot and needle to its highest position; hold the needle thread taught with your left hand, lower the needle into the thread plate using your right hand, and then raise the needle. As you raise the needle, the needle thread will catch the bobbin thread, and pull it up. There should be a loop of thread intertwined with the needle thread. Use tweezers, your finger, or a straight pin to retrieve the bobbin thread that is visible through the thread plate, and pull it through the plate.Place the fabric under the presser foot, and drop the presser foot. Choose the stitch you want to use from the top stitch display, right above the top thread feed. Press the '0-9" button located on the sewing machine's front panel, and a display screen will come up. Input the thread number, and press the 'OK' button located on the sewing machine's front panel.-----------this is procedure.
    If problem persists.Remove bobbin and clean lint from bobbin and re-tight the bobbin properly, then check.This should help.Thanks.Helpmech.
  • Posted on May 16, 2011
    Can you sew leather or vinyl on Husqvarna 415? If so, what tension, needle and foot should I use?
    Ok. Depending on the thickness... garment weight leathers can be sewn with a domestic machine... Most often an even feed foot (the home version of a walking foot) is needed. You will likely need a larger leather needle and somewhat longer stitches than you would normally sew.
    As for stitches looking messy on the back that is a top tension problem... you'll need to tighten the tension until that goes away. AFTER you have made sure you have your machine threaded correctly with the presser foot in the up position.
    Aug 19, 2012 | Husqvarna Freesia 415
    Bernina 1008 troubleshooting
    the best thing to do is have the machine serviced at a sewing machine
    shop
    May 05, 2012 | Bernina 1008
    How do i thread my needle with the singer handy stitch?
    1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
    2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
    3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
    4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
    5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
    6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
    7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
    Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
    My machine is making a loud banging noise
    These are the things that cause my machine to make a "banging" sound:
    The machines with the horizontal/drop-in bobbin sometimes collect lint in the bobbin case.
    Sewing fabric backed with a synthetic/foam/vinyl or adhesive.
    Wrong size needle for the type of fabric being sewn.
    Mar 13, 2010 | Sewing Machines
    Needle timeing is out
    The timing is set at the factory. If the threads are not hooking together, then perhaps try one of three things.
    1. remove the thread, and run the machine at full speed for three minutes or more. This warms up the hardware, loosens gelled up oil, and get's all the parts in allignment.
    2. (and 3.) Check the thread tentions. On the top thread, it will be a dial with numbers, over a spring and two plates that the thread runs through. On the bottom, it's a tiny screw on the side of the casing that the bobbin sits inside.
    If the machine sews loose threads, then tighten these, a bit at at time, and if the machine jams up with a knot of thread at the needle, then loosen these. I believe that if the sewn threads are loose at the top, the bobbin tention neeeds tightening, and if the sewn threads on the bottom are loose, then the top tention dial needs tightening.
    Cheers.
    Aug 22, 2009 | PfaFF Creative 7570
    Sewing Machines Logo
    55 people viewed this question
    Top PfaFF Sewing Machines Experts
    Douglas Plant
    Douglas Plant
    Irene Tulloch
    Asmodius
    Level 1 Expert
    Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
