Computers & Internet Logo
Posted on Dec 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a gs724t and need to add a gs748t, what cable do I use to link them together??
Justin
Level 3:
  • Master 2,072 Answers
  • Posted on Jul 13, 2012
Justin
Master
Level 3:
Answers
2072
Questions
0
Helped
432056
Points
5629
Most switches are smart enough to detect and reverse logic if the wrong cable is used. If you want to be correct you would use a crossover cable.
Computer to computer, router, or extender (crossover)
Computer to switch or hub (straight through)
Switch/Hub to Switch/Hub (crossover)
How and where do you install nvidia video bridge cable asus 14010-00131200.
Hi
The video bridge cable you are referring to is I believe "Flexible NVIDIA Video SLI Bridge Connector Cable".
This is to link two graphics cards together for enhanced graphic capability, especially gaming. You would need two SLI compatible graphics cards, they should be identical, in the relevant PCIe slots on the motherboard and this cable then links them together.
If you are only using one graphics card or the onboard graphics then this linking cable is redundant.The Youtube video here:
Nvidia How To SLI Tutorial
is pretty good at showing what you need to do and where this cable goes when appropriate.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Unable to detect my Netgear Gigabit smart switch GS748T via Smartwizard discovery. Earlier have tried reset the switch to factory default but to no avail. Pls help.
First, make sure your switch and PC are in the same broadcast domain/subnet, and that there is a DHCP server in operation.
Second, make sure you are following the "factory reset" procedure correctly (http://support.netgear.com/product/GS748Tv1).
Third, check your version of Smartwizard Discovery, and download a newer version if one is available. I think the latest version is 2.05.05 (download from http://support.netgear.com/product/GS724Tv2).
110 line in to light switch. How do you continue 110 line out to other oulets or switches?
Add another line to 120V switch.
To begin, inside your switch box, there must be at least two cables.
Each cable has a black-wire and white-wire and bare ground wire.
If your box has only one cable, then you cannot use that for your junction.
OK, your box has 2 cables.
One cable comes from circuit breaker box. These are called Line wires. There is a Black Hot and White Neutral.
The other cable goes to light. These are called Load wires.
You are going to add a new cable with a black-wire and white-wire
In back of box, the white wires are twisted together and covered with wire nut.
These white wires are called Neutrals.
Add your new white wire to these other white wires.
The switch has 2 black wires. One black wire is the Hot line wire.
Add your new black wire to the switch screw that has the Hot.
Of course the switch has 2 black wires, so how do you know which is the Hot.
Turn light switch off, turn power ON, and test each black wire to bare ground wire.
Tester lights up on the Hot.
Review:
New white wire connects to other white wires that are twisted together and covered with wire nut.
New black wire connects to Hot wire.
Ground wires are connected together.
On your new receptacle, the black wire connects to brass screw, and white wire connects to silver screw.
Screws are color-coded to tell electrician how to wire.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
I have several Netgear GS724T switches, the smart wizard seems to discover some of the switch, and not others. However, my biggest issue is not being able to access the web interface. It seem I can not...
This is odd. Note that "on the same subnet" means the switches need to be within the same physical broadcast domain as your computer.
If a port on one of these switches is configured so that the default VLAN is other than 1, it might prevent the switch from receiving DHCP; I'm not sure if it would prevent Smartwizard from seeing it.
If all else fails, reset the switches' configurations with the "Factory Defaults" button to start over from a known state.
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
2answers
Data cable operation for i580
Just the cd that comes with the cable. It has USB driver on it so the computer and phone can link together.
2answers
My netgear switch GS748T gets hung and needs a restart or reboot very frequently.
chk if its not geting heatup......
also check for viruses on the network as they also jam the network communication
Netgear switch GS748T smart switch needs reboot very frequent
(Answering a six-year-old question...)
From the description--especially the part about having "spanning tree" disabled--the first thing that I would do is look for network loops. STP/RSTP ("spanning tree") detects these loops, and disables ports to prevent packet storms. If that is the problem, enabling STP should clear it up--but you also want to make sure you want those loops in the first place.
2answers
Ethernet adapter
You will either need to add a switch, or you need a crossover cable to do a direct connection. It also helps if both computers have the same workgroup label. Then you need to turn on sharing for the folders you wanted to access.
Installing a second dvd drive
1. In your ID cable there are three connectors first one go’s to mainboard that is blue other two connectors black can go ether any one of your drive.
2. Jumper ether one should be in master and other should be in slave.
3. if your ID which connector mainboard to drive is only with two ends than you need to buy one ID Cable with 3 connectors in it.
Grand Canyon Tech
Grand Canyon Tech
