Question about BenQ Cameras
My camera notifies protected card any time i inset a card in it. the card did read before but now it has suddenly started to be rejected by the camera.i don't know what to do now.
My camera rejects memory cards.but it functions properly without a memory card,since the internal memory is too small it can store more than 10 pictures so i am obliged to use a memory card so i need some help so as to fix this out.
Posted by Lewis Agile on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • BenQ Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Dec 30, 2011
How do I fix a read-only SD card?
Is the read only / write protect switch in the correct position ?
Oct 04, 2015 | Samsung Plus 4gb Micro Sd Sdhc Mobile...
My camera says Write Protect! And my memory card is unlocked..it appeared when i was uploading pictures and all of a sudden `write protected`appreared and I cannot use my camera or take any photos...w
Have you tried a new memory card,or reformatted the existing one?
Or go on the menu on the camera and restore all the original factory settings?
If none of those work it might be time for a new camera!
Mar 23, 2014 | Olympus Tough TG-310 Digital Camera - Red...
Camera reads card lock when trying to take a photo
Since you neglected to specify the make and model of your camera, I'm going to assume it uses SD/SDHC cards.
Oct 17, 2012 | Cameras
Write protection on a Transcend 8GB CF card
Having pics on card you don't want to lose is another matter...sometimes a pc won't recognize the cardreader...I have hade to go thru windows explorer/computer/removable drive F:...YOU GET THE IDEA, good luck.
Feb 17, 2010 | Cameras
Camera and video on standby mode
swith off the phone 5 minetes remove the battary after u inset battery then on the phone...........
Jun 13, 2009 | Nokia 3600 slide Cellular Phone
Sony Handycam DCR-HC38 is rejecting the head cleaning tape
camera has bad tape loader and or bad tape sensors. sounds drastic but bang it a few times with the palm of your hand. if this doesnt work contact sony service center
Jun 01, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Wont read my camera sd card.
  1. You need to install your camera software on your new computer.
  2. Restart computer.
  3. Inset SD card.
  4. Goto start open My Computer.
  5. Look for SD card should see it under removable disk.
  6. If still not working send MSG & we will go Further.
Mar 08, 2009 | Computers & Internet
Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
Feb 12, 2009 | Nikon Cameras
Card Reading Write Protected
hi there
some card do have a physical lock onto itself to protect files.
please check your card and look for a small switch, its usually at the side. click it up or down and try re inserting it to your cam. if this still isnt any help, it must be a setting on your cam.
hope this helps. :)
Feb 06, 2008 | Olympus Stylus 410 / ? 410 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Cameras Logo
74 people viewed this question
Top BenQ Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
ChinthakaJ
ChinthakaJ
Are you a BenQ Camera Expert? Answer questions, earn points and help others
