Marjorie Love Posted on Dec 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm not quite satisfied with color and black tone. What settings would you recommend.
Anonymous
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Dec 30, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
331
Questions
0
Helped
93076
Points
691
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Best picture calibration settings
For any TV; irrespective of its brand or type, set the contrast to 70 to 80%; brightness to 30 to 35% will produce a clear and vivid picture in B/W. Set the color to Zero, and check this first. After you have satisfied with the picture in Black/White [B/W], advance the color intensity, according to your viewing taste. This adjustment will depend on individual taste. Anyway, note the skin tone of the news reader at the studio. Take this color a reference. That's all.
Nozzle check for Printer
take out the colors and see if the black prints. if not you could need a new one.
' Printing Weak Magenta CM1015
You can increase the dencity of each catridge, before that set as difault setting, do color calibration, check if not satisfied inrease the dencity of megenta in menu#system settings#quality#catridge#megenta#+1 or +2 or +3 choose desired quality,even you are not satisfied clean the laser scanner assm..
1helpful
I have new canon pixma mx 328. how to do fax operations of sending and receiving
Hi!
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Severe color banding and color shifting for skin / hair tones
Think u got some kind of magnetic field interference.Move ur tv set to the right or left couple inches,just make sure not be to close to ur other electronics devices.Go in ur tv menu.Go to PICTURE.Go down to reset,the setting will go back factory setting,so the colors.See if that help.
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
2answers
Grey tone problems
Hi,try this: in the printer driver choose imaging and find "color reproduction" button. Just adjust that balck and gray will be printed FROM BLACK TONER ONLY(print black text and graphic from black toner only)
Regards
Color is way off
Hi , need head cleaning , until the color will have true color .
use original canon ink cartridge you will satisfy sharp colors.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
