SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
SOURCE: Front wheel problem with Peg Perego Aria single stroller
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
SOURCE: phil and teds sport stroller
you can, you just pull the pin out and turn the wheel round and re pin it, for more help log on to phil and teds.com where there is a video to show you how to do this and much more.
SOURCE: problem with front wheel of jane 3-wheeler stroller
The front wheel swivel has become a problem with some strollers that are a little longer than the standard three wheel stroller. This has been happening with the new Phil & Ted's Vibe as well.
This can be approached in a few different ways. The easiest is to take the wheel off completely and properly lube the connection pieces. You can use a standard axle grease, or WD40 if you have some in your home. When the tire is properly lubed, re-attach it. This should take care of the problem.
If that does not work, the wheel's inner tube might be/have been over-inflated. When this occurrs, a part of the tube bubbles and causes the wheel to wobble while being pushed. Deflate the tire slightly and see if this helps. If the tube has been over-inflated for some time, it may be necessairy to completely replace the tube - you can do this at most bike shops that sell replacement tubes.
If this does not stop the tire from wobbling, please feel free to contact us anytime.
[email protected]
StrollerInfo
www.StrollerInfo.com
