Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishawasher floods Water starts entering the unit and overflowing, flooding the kitchen, even when the dishwasher is not turned on.
Posted by David McConnell on
Anonymous
    New Friend:
    Problem Solver:
Two possible reasons come to my mind. First, and simplest, I've seen Dishwasher installations that did not use a air gap in the Dishwasher drain (usually a dome device mounted on the back of the kitchen sink or sometimes mounted in the wall just above the sink in older homes).When an air gap is not used, it is imperative that a high loop is formed in the dishwasher drain line, and tied up in that position (usually under the kitchen sink,as high as possible- the underside of the sink faucet usually works, or a screw into the bracing under the counter top to wrap a soft wire looped around the drain hose to hold it there permanently). If you do not use a air gap, or have a high loop in the dishwasher drain hose, then likely you are getting a back flow of dirty water into your dishwasher from the drain plumbing to which the dishwasher is connected (likely the garbage disposer or the tail from the sink basin.) So every time you either run the disposer (if you have one), or drain the sink basin, some of that contaminated, dirty water may be siphoning back into the dishwasher There are some exceptions, as some dishwashers including some whirlpool models, have a anti siphon ball device built into the drain pump housing.( You should also check your local plumbing code. They may require an air gap in your dishwasher drain line regardless of anything else.) Secondly,the water inlet valve may be sticking open, or not completely seating closed after the fill cycle. This could be indicated by a very gradual accumulation of clean, clear water in the bottom of the tub, to the point of completely filling the bottom of the tub to the point of overflow at the dam at the front bottom of the tub. The speed of overflow will be determined by how poorly the diaphragm inside the valve is seating. If you suspect this may be the problem, pull the rubber hose off the OUTLET end of the valve, with the machine in the OFF position or better yet UNPLUGGED (water and electricity do not mix, and can KILL you) ,and see that there is not a continuous flow or trickle of water. If there is any flow of water, in this scenario, then you have a bad inlet water valve, and the valve should be replaced rather than attempting to repair. Be sure to reconnect the rubber hose to the inlet valve before plugging the machine back in and attempting to run the machine, or you will have a high pressure flood, and likely electrical shorting under the machine which could likely ruin the machine.
Posted on Dec 30, 2011
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Code 15
This is indicating a flood issue the flood switch in the base pan is activated. remove the unit from under the counter take the left side off. Dry the water up then watch it to see were it is leaking from.
The float switch/level sensor in the rinse boiler has not activated. This could be a faulty solenoid not letting the water in (assuming the isolating valve is turned on), or a faulty float switch/level sensor. This would result in water overflowing through the rinse arms and the overflow in the rear of the wash tank.
Hope helps.
May 13, 2011 • Dishwashers
We have water at the bottom of the machine. should we re-rerun but we are concerned about overflow.
When you start a cycle, the first thing the dishwasher does is go through a pump out to make sure all water is out of the unit. Even if water remains, there is a float switch located within the water fill mechanism on the left side of the machine which would not allow a flooding condition to occur.
2answers
1helpful
2answers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
8helpful
Bosch dishwasher model shu3300
Your machine has detected a "flood" condition and has defaulted to its flood mode. Meaning that only the drain pump will work until the flood is fixed.
Bosch D/W's are pretty slick, the entire unit is sitting inside a drain pan that's designed to catch an overflow (flood) keeping the water off of your floor. This overflow pan has a Styrofoam float that rises with the flood and trips the "flood mode". The water in the pan has to be removed allowing the float to drop back down before you can use your dishwasher again.
There are 2 ways to do this... the easy way and the hard way.
1.) Easy way---> Wait a few days. The water will eventually evaporate out of the drain pan all by itself. Takes longer than the hard way, but no tools are involved.
2.) Hard way---> (not actually "hard") TURN POWER OFF TO THE DISHWASHER! Remove the lower kick panels (below the door). Remove the 2 screws holding the water valve in place, and push the valve up as far as you can. Now use a "Shop-Vac" with a long crevice tool attachment. Stick the crevice tool in where the valve was... make sure to reach in there about 8 or 9 inches, (the safety float is in there on the left, you can see it with a flashlight) otherwise it won't reach the water. Now simply suck up as much water as you can. You won't be able to get it all, you just need enough removed to drop the float.
Now try your D/W... after a normal 2 minute drain, it should fire right up.
2answers
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
9helpful
10answers
Flood protection is activating
Had the same problem on a Miele mashing. In my case trying to clear a drain blockage in a kitchen sink had probably forced water back into the washing machine and caused an internal leakage. Rather than remove the whole machine and tip it over, I opened the small panel at the front bottom (behind the skirting panel) (needs 'special' screwdriver for the 2 screws) and removed the water that was lying on the base of the machine. Not much (less than 5mm) but enough to lift the white polystyrene float (a round disc about 10cm diameter) which was activating the micro-switch and causing the F70 message.
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Ekse
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
