First u have to check that ur microphone is working correctly or not for this use hands free. If hands free works perfectly then then ur microphone speaker is damage u have to change it.
Make sure the webcam mic is set as default TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Have you made your webcam mic the default mic ? Vista TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
You may not have designated the webcam mic as default
make sure the webcam mic is set as default - especially importsnt if you have laptop with a built in mic as well TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device - enable" click OK Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice Set webcam mic and speakers to show Default equipment Open Video and Voice Setup to test audio equipment Click 'Place a free test call' Check box 'Allow USB devices to access Messenger' Click 'Apply' click 'OK'
Before you can set your mic as default in any chat program you have to make it default on your computer first. Especially if you have a laptop where you will now have multiple choice for mics Vista audio set-up
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;}
a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;}
a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;}
a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;}
a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;}
TEST SPEAKERS
visible
Set required mic as default - click on mic font to highlight and click
"Properties"
Click "Levels" tab and set sliders to 100% ( adjust to suit later)
displays Restart computer Retest
When you go into a program to use your mic you will have to tell that program which mic is default WLM (MSN) Open menu > Tools > Audio & Video setup
