I have this problem also with Fuji Z90 model. Problem is fixed and focus now working ok. Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted
for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start
working. I need to make small adjustment . Reason when camera is
started picture is not clear and before using camera i need to do full
zoom in and back zoom out. After this picture is crystal clear and all
working ok.
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
First, remove the remaining films from the camera. (while your camera is switched off)
Second, press on both the shutter button and the power button at the same time. (to reset)
Third, reload a new set of polaroid films into the camera.
Hope it helps!
It's a message given when the internal lenses get jammed, possibly due to debris within the gears that move the focus. The "Focus Error" message can involve many FujiFilm models.
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Check out this link:www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link.Everything on the web said it would cost ~$100 to fix.I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working.Dropping the camera loosens the debris and voila!
If it's showing an "E", then the film is not uptaking properly, even though it may be advancing. Try reloading the film, or, if for example you're shooting Fuji film, try switching to Kodak, or another brand. Mine will show an "E" for Fuji alomost consistently, but not with Kodak.
