I now know that there is a electrial fault with it and the door is locked and will not release and i have dirty clothes in there has i just loaded it up to wash the clothes and it would not power on so the door locked and will not release now and i need to get the clothes out to wash ready for my kids and husband for work and school please help me thanks j callaway
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
SOURCE: a hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
SOURCE: DI 'My self' Washing Machine Door Rubber
Hi.
I strongly advise you not to attempt this repair yourself, as it is quite involved, and unless you know what you are doing you could easily danage delicate electronic components if you are not careful.
It involves removal of the control panel , the front panel of washer, the door lock assy, and disconnection of electrical parts.
In your own interest, get some one in.
Plz rate my comments.
Thanks.
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
