YOUR PHONE'S ANTENA INSIDE THE PHONE IS NOT FUNCTIONING. MY PHONE DID THE SAME THING. THE BOYS AT WWW.FIXOLOGYEREPAIRS.COM FIGURED THIS OUT FOR ME. YOU CAN GET THIS REPAIRED FOR ABOUT $60.- .
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
From the Home screen, select Go to.
Scroll to and select Profiles.
Scroll to and select Flight.
Select Activate.
To turn off airplane mode, follow these steps:
Scroll to and select Normal (or a profile other than Flight.)
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode" If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢) NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active. To turn Airplane mode on or off, refer to the following: ---------------------------------------
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps: 1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps: 1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
How Do I Access Airplane Mode On My MetroPCS SCH-I220 (Code) Phone?
Although the handset does not feature the traditional airplane mode function, all wireless connections can be disabled while still allowing the use other common tasks, such as Microsoft Office Mobile applications, Windows Media Player and games.
To disable all wireless connections follow the steps below:
From the home screen, press the left soft key for Start
Press the left soft key for More
Select Settings
Select Connections (6)
Select Wireless Manager (1)
Highlight All then press the OK button to disable all wireless connections
To turn off flight mode, repeat these steps and it should turn your phone back on.
