Konami Castlevania: Lords of Shadow Logo
Lonnie Hardy Posted on Dec 30, 2011
When fighting an enemy they ask u to hit RT for finishin off move .rRT alone does not work n I cant figure out what other button to use I will hold down RT and i cant finish off the boss I tryed rapid
I cant beat the the end monster on the first level it keeps popping up on screen to hit RT but it dont work
dark_drag278
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 20, 2012
dark_drag278
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
79
Points
Had that problem to you gotta be standing right on top or right next to that big branch thats flashing on screen
Best cheat codes for infinity blade III on ios
Restart bloodline 1, when you are fighting the dark knight and learning how to your shield. Purposely die by blocking and stop blocking before he hit hits you. After you die you start with a really awesome set of stuff that is not in the shop without this cheat. There is two other things for every type of item that you can get that you can\'t get without this cheat. The only problem is that you can\'t equip anything other than these awesome things.
Master Killer
First you must have less than 50% battery remaining so your device doesn\'t have enough power to catch this glitch. First make sure you have 0-100 gold ONLY. Now, equip a sword so that your hit points will equal 25. Now encounter an enemy and kill them using NO magic. Your gold should go up to 1900-5000. Now encounter another enemy and attack until their health is about 1000-1100. After you do this step, HIT (not scratch) them the same number as your hit points (25). EXACTLY on the 25th time pause and go to store and buy until your gold reads 500 or less. You want to have the most as possible. Now unpause and finish them. For the rest of the bloodline your sword will deal the amount of gold you have left (i. e . 467) Now you can just farm enemies.
tip
Best Build Brody
Best Brody build guides for Mobile Legends 2022. I works hard to keep my's Mobile Legends builds and guides updated, and will help you craft the best Brody build for the meta pastigames . Learn more about Brody's abilities, Items, Emblems & Strategy.
Brody Skills
  • ABYSS CORROSION - With his Basic Attack Basic Attacks resonated with the Abyss Power within his body, Brody is able to move channeling at the cost of having longer channeling and the lower Attack Speed bonus. Brody can cast skills while channeling his Basic Attack Basic Attack. Brody's Basic Attack Basic Attack will still hit the target even if it has gone out of range despite its channeling time. Each Basic Attack Basic Attack deals (+200% Total Physical ATK) Physical Damage, slows the enemy by 25% for 0.5 second and inflicts 1 stack of Abyss Mark on the enemy, capped at 4 stacks. Each stack of Abyss Mark increases Brody's Critical Damage against the target by 12.5%. If Brody's Basic Attack Basic Attack is Critical Icon critical, he gains 25% Movement Speed for 1 second.
  • ABYSS IMPACT - Brody launches a shock wave in designated direction, dealing 250 / 290 / 330 / 370 / 410 / 450 (+60% Total Physical ATK) Physical Damage and inflicting Abyss Mark on enemies hit. As the shock wave travels, for each enemy it hits, it deals an extra 33% damage and applies an additional stack of Abyss Mark, capped at 200% damage and 4 stacks.
  • CORROSIVE STRIKE - Brody dashes to an enemy, dealing 200 / 230 / 260 / 290 / 320 / 350 (+75% Total Physical ATK) Physical Damage, stunning the enemy for 1.2s, and inflicting 1 stack of Abyss Mark on the enemy. Upon hitting the target, he is able to move one more time in the movement direction.
  • TORN-APART MEMORY - Brody locks on all the targets within 8 yards, dealing 300 / 390 / 480 (+80% Extra Physical ATK) Physical Damage to them. If the target has an Abyss Mark, all Abyss Marks will be reset, dealing Physical Damage equal to 200 / 260 / 320 (+50% Extra Physical ATK) plus 8% of target's lost HP for each stack the target has.
Brody play Strategy
Early Game: At level one unlock your skill 1 and go to Gold lane. While laning try to hit enemies through the minion wave with your first skill.
Mid Game: Don't fall behind in the economy. Your main damage will come from your build so try to complete it and focus on the farm. Do not initiate unnecessary fights, instead of that do a quick rotation in mid lane in order to do a successful gank with your mage.
Late Game: In this phase, Brody will shine the most. Try to stay with your tank. Follow your minimap before ganking. Do not ever use your ultimate first, try to hit it when enemies are low on HP.
on Jun 03, 2022 • Games
I am not getting "folder options" option in Tools option of the menu bar................second prob : my D:/ and E:/ drives do not open to a double click.by doing so,it asks me to choose from a list of...
You can use the RRT tool which will enable the task manager ,you can see the folder options this can be downloaded from http://www.softpedia.com/progDownload/RRT-Remove-Ristrictions-Tool-Download-68926.html
There will be autorun.inf which will be present as hidden in your drive .in the folder options select show hidden files and folders and uncheck the option of Hide protected operating system filesby doing this you can view hidden autorun.inf and can delete it
Cant beat the boss
You will have three fights. In the first fight, be sure that Spyro and Cynder are in their gold armor. You may want to put Cynder in Black Armor, because her Fury Breath is ten times better in that one. Depending on how you are playing ( By yourself or with someone) Use Cynder's poison or fear scream to stun Malefor, then use Spyro to hit him. If you do it right, green magic gems and red health gems will fly out of Malefor. He will then zoom past you and start throwing those damn fire balls at you. Use your spinning action to spin around them. Do the same thing, using Cynder's posion and Spyro's electricity to fight him. It really is key to actually HIT him and not use just magic. At the bottom right hand of your screen, you should see Malefor's health begin to deteroiate. When it gets low enough, it will go to a cutscene, where you will have to press different buttons. If you do it correctly, the world will begin to destory and that leads to the 2nd fight. In this fight, it took myself and my boyfriend ( we played it as two player) forever to pass this part. Malefor will shoot ice and purple fire balls at you. Again, use your spin action to get around these. Be careful though, because the purple balls will target either Spyro or Cynder. Use your magic from time to time, but this is when you really want to HIT Malefor. Use Cynder's poison and Spyro's electricity, BUT Use combos, ( Mainly the Square button) and really just beat the **** outta Malefor. Towards the end, you will want to go into Fury Mode. If you dont know how to do this, hold the triangle and square buttons together . Just hold them, dont press them rapidly, just hold them. Spyro and Cynder willl form purple and blue balls around them, then shoot beams of power out of thier mouths. (( Malefore's health needs to be low enough for you to do this). It will then go to another cut scene. You will have to press the buttons in the order they appear on the screen. Okay, now you are at the last fight. Malefor will have a purple bubble around him. HIT THE BUBBLE TO REBUILD YOUR FURY METER. Once your fury meter is full, go into Fury mode again and then it should go into another cut scene. Press the buttons in the order they appear on the screen and there you have it. It will show the ending and then the credits. Wait after the credits for a special scene. Hope this helped you alot,
hope that helped
Cant figure out how to play perfect dark seems to be no enemy
Goto single player campaign.. there's missing briefing, which tells you what to do. Follow the prompts given on the screen during gameplay as well.
Hit start during the game there should be an objectives tab
4answers
Cant get cheats for turok for the ps3
1.www.gamewinner.com 2.www.cheat beast.com 3.www.cheatcc.com
1helpful
DS will not move past aura selection.
Keep ur thumb or stylus COMPLETELY still and DO NOT BREATHE the microphone will sense if u do and make u wait longer it took me a while 2 figure that out
3helpful
God of war 2: challenge of the titans mode
CHALLENGE 1 - BLIND FURY
BONUS: SHATTER TWO ENEMIES
For this battle, equip Euryale's head and freeze the Cyclops first (so
he doesn't distract you). Freeze the other two enemies and then shatter
them to get the bonus. Now attack the Cyclops and grab that eye!
NOTE: You can replay this challenge to gain more Cyclops Eyes! Gain
20 eyes to unlock a special costume!
CHALLENGE 2 - DEATH FROM ABOVE
BONUS: KILL 15 ENEMIES IN THE AIR
The best weapon to use is either the Athena Blades or the Spear Of
Destiny. For the spear, use the Triangle + Triangle combo to toss an
enemy into the air and attack them. Try to avoid fighting the bigger
enemies and focus on the smaller ones.
You can only toss the satyrs, soldiers, and gorgons into the air! You
can't fling the berserkers or minotaurs into the air so don't even try!
CHALLENGE 3 - GORGON GRAVEYARD
BONUS: SHATTER 35 ENEMIES
Equip the Barbarian hammer and Euryale's head. Use the Super Gaze
attack (L2 Button + Triangle) on each enemy and then pound on them with
a hard attack with the hammer to shatter them. Use the Fleece to defend
from the other gorgons!
CHALLENGE 4 - PROTECT THE WEAK
BONUS: KEEP TRANSLATOR'S HEALTH ABOVE 50%
This is a very lengthy challenge. The translator sits on a glowing
circle. Every 30-35 seconds, the circle will move to a different area
and you MUST move him towards the circle's new location or he will
start to lose health. As for the enemies, abuse the Amulet and pound
all of them with your hardest combos until the game says you are done.
CHALLENGE 5 - REAP THE REWARDS
BONUS: COLLECT OVER 600 ORBS
CHALLENGE 6 - SURVIVAL OF THE FITTEST
This is also a very lengthy challenge. Your health will continually
decrease throughout the challenge and you gotta keep the dead bodies
flowing (sort of like Shinobi). Survive the onslaught to complete the
challenge!
CHALLENGE 7 - PERFECTION IS DIVINE
Hopefully you've perfected the art of countering with the Fleece
because there's no other way to complete this challenge! Keep your
distance from the petrified minotaur and pound combos onto the other
enemies. You MUST kill the priests or else the challenge won't end!
Once all the other enemies are gone, deal with the minotaur and kill
him with a fatality!
Pirates of the caribbean wii
just kill your enemies as long as you have to when another guy calls for help go over dont just sit and fight and remember to block Z and if this dont work take to mind that it is the last level
Top Konami Video Game Consoles & Games Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Marty Warge
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
