Sony VAIO S360 Notebook Logo
keith kawashima Posted on Dec 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd error code 10
Error code 10 for dvd
Bee Santiago
Level 2:
  • Expert 268 Answers
  • Posted on Dec 31, 2011
Bee Santiago
Expert
Level 2:
Answers
268
Questions
0
Helped
156114
Points
387
Cause of the Code 10 Error A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
The safest thing to do is to perform system restore or
run SYSTEM RECOVERY.
If you will use sysem recovery it fix all the problem of your computer however all files on your hardrive and softwares that you installed will gone.
It will be back from original manufacturer settings just like the same thing you got your computer.
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
1helpful
Cd/dvd has as error code 10
i had the same problem error code 10 in my laptop, i taught the problem will be in the cd/dvd but i try to format the windows.and it seems the lens is working and reading,and it continues installing until the windows loaded and the cd/dvd working good.
2answers
Nothing happens when i put in a dvd or a CD. Under the driver information, it says that i´am having a error code 10.
error code 10 = either the device is not present, is not working properly, or does not have all the drivers installed. this code may also have a manufacturer specific error message associated with it, depending on the device.
Solutions, check the device connections, and check and/or update the drivers.
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
2helpful
CODE 10 ERROR
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
[email protected]
2answers
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Sony vrd-vc20
a code 10 error refers to a hardware failure, where the dvd cannot be communicated with due to it being faulty.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
