Question about Watches
I cannot set the time on Armitron All Sport 45/6999 watch or Pro sport 49/1018. Came w/ no instructions and can't find this model # on Armitron website
Tried following instructions on Armitron website for other models but every time they say to press a button and you'll see the minutes flash, this does not happen. Of course these instructions are for different models than mine as they do not have this model's instruction on their site.
Posted by maria pimley on
Chad Lehman
I found instructions here. http://www.livestrong.com/article/306545-armitron-black-red-womens-sport-watch-instructions/
Although, I can't figure out how to turn off the alarm.
Posted on Mar 22, 2012
5 Related Answers
Gene Lawson
  • 51 Answers
SOURCE: changing the time on my wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Posted on Feb 27, 2010
Anonymous
SOURCE: Armitron All-Sport M518, 40/6755
I have the same watch- instructions are hard to find.
Do this: hold the mode button for a few seconds, until the alarm time blinks. Push mode again and the time will blink, then push st/stp to change to minutes or hours, and press adj. to change; press mode when you are all done.
Anyone know how to go from 24 hour (military) time to regular 12 hour am/pm time?
Posted on Jul 10, 2008
Anonymous
SOURCE: Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
Posted on Jan 16, 2009
Anonymous
Hold the "reset button" about 30 secs, than the hour starts flash and you can change them pushingst/sp button. Martin
Posted on Mar 21, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: CANNOT SET TIME OR DATE AND ALARM
Follow this link and find instructions:
http://www.armitron.com/watch_instructions.asp
Rate, please.
Posted on Mar 31, 2009
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 | Watches
    How do you set the time on an Armitron 165 wrist-watch?
    Hi wtgillo,
    Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
    I would be more than glad to give you details on how to, Please see steps below.
    • Your Armitron Watch will have Four Button on the side of the watches rim.
    • Button on the upper Left is MODE.
    • Button on the lower Left is LIGHT.
    • Button on the upper right is DATE.
    • Button on the lower right is Alarm.
    See Steps below:
    *Setting the time*
    • Press and Hold down the Mode Button til the Hours flash
    • Then push Alarm Button to set the Hours
    • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
    • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
    • Press the Date again till the Date flashes, then push Alarm to set date
    • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
    • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
    I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
    Have a nice day,
    mvincentc
    Apr 21, 2011 | Armitron Watches
    How do i set the time and date on my watch?
    This is direct link to all ARMITRON watch manuals/instructions: http://www.armitron.com/watch_instructions.asp
    or
    You can also try with this approach. This is for Armitron WR 330,but i believe this could also help you.
    The following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch.
    "ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
    To set the time, date, and day of week:
    Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
    Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
    Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
    Use the "ADJ" button to change the value of the setting.
    Touch "MODE" to save the settings and return to time mode.
    Thanks for using Fixya. Please rate the solution.
    Nov 06, 2010 | Armitron 165 watch
    How do I set the hour, minute, date etc.
    Thank you for contacting FixYa.
      Setting the Time and Date
    1. To set the time and date on your Armitron digital watch, begin by pressing the "A" button while in time-telling mode. The seconds place will begin to flash; press the "C" button to reset the seconds to "00". Press "B" to set the hour, and press the "C" button repeatedly until the desired hour is reached. Press "B" to set the minutes, pressing the "C" button until the desired minute is reached. Press the "B" button, followed by "C" to set the month, date and day of the week. When you are finished programming the time and date, press "A" to save and return to time-telling mode.
    2. Using the Chronograph
    3. To use the chronograph feature on your digital Armitron watch, press "B" while in time-telling mode to access chronograph mode. Press the "C" button to start the timing; press "C" a second time to stop the timing. To reset the chronograph, press the "A" button. Press the "B" button at any time to return to time-telling mode.
    4. Using the Split Lap Chronograph Feature
    5. To use the split lap feature on an Armitron digital watch, press the "C" button while in chronograph mode. Press the "A" button to measure splits or laps; at the end of the event, press the "C" button to stop the timing. Press "A" once to see the final split or lap time, press "A" twice to reset the chronograph to "0". Return to time-telling mode by pressing the "B" button.
    6. Setting an Alarm
    7. To set an alarm on your Armitron digital watch, press the "B" button twice to access the alarm mode. Press the "A" button and wait for the hours place to begin flashing, then press the "B" button twice. Press the "B" button, followed by the "C" button to set the hour and minute of your alarm. When you're finished, press the "A" button to save the alarm. Press the "B" button to return to time-telling mode.
    8. Using the Countdown Timer
    9. To use your Armitron digital watch as a stopwatch, begin by pressing the "B" button three times while in time-telling mode to access the countdown timer mode. Press the "A" button, followed by the "C" button to set the hour. Press the "B" button, followed by the "C" button to set the minutes and seconds. Once you've set your timer, press "A" to return to countdown timer mode. To stop the countdown timer, press the "C" button. When you are ready to reset the countdown timer, press the "A" button. To return to time-telling mode, press the "B" button.
    Best regards. Jewel
    Sep 03, 2010 | Armitron Digital Sport #45/6967PNK Watch
    How do I turn off the alarm on my Armitron watch?
    I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
    Nik.
    http://home.earthlink.net/~eldonenew/armitron.htm
    or
    http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
    Other People Are Reading
    Setting Date, Time and Alarm
    • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
    Using Chime and Alarm
    • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
    Backlight
    • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
    Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
    I have an Armitron 40/8125 watch. I try to set the time as follows 1)Hold B - Alarm hours flash 2) Press C - Alarm minutes flash 3) Press C - It goes back to Alarm hours flashing where it should advance to...
    You need to press button A to enter the time setting mode and then press C.
    If you have lost your instructions, you can get instructions from the Amitron web site.
    Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
    instructions.
    Choose the one that looks like yours and download the PDF file.
    Mar 18, 2010 | Armitron 40/8125BLK Digital Sport Watch
    Setting Armitron Watch model WR330
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
    Mar 14, 2010 | Watches
    How to set an Armitron WR330 Watch
    he following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch. "ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
    The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
    Check:
    http://www.armitron.com/WatchInstructions.html
    Mar 15, 2009 | Watches
    Ladies Armitron 45/6967
    Armitron alarm/chrono
    1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
    2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
    Hope this helps!! K~~
    Sep 27, 2008 | JCPenney Armitron Sport Link Bracelet...
    Armitron Watches
    From the time telling mode press the set button the seconds will flash.
    Press the mode button the hours will flash
    Press the adjust button to change the hours
    Press the mode button the minutes will flash
    Press the adjust button to change the minutes
    Press the mode button the month will flash
    Press the adjust button to change the month
    Press the mode button the date flashes
    Press the adjust button to change the date
    Press the mode button the day flashes
    Press the adjust button to change the day
    Press the set button when done.
    Mar 11, 2008 | Watches
    Watches Logo
    1,499 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
