Question about Just Wireless Bluetooth Headset Wireless Headset
Lost manual for my Just Wireless Blue BTMP-50K. How can I get another manual?
Posted by Keith A Langlois Sr on
Blue smoke
Blue smoke (how many miles on engine, 50k or 500K???????
to some this means, burning oil, others steam
it that blue smoke lingers a long time that is oil burning
and smells just like oil burning.
and means 2 things,
1: engine burns oil.
2: if car had autotmatic trans the vacuum modulator love fail
and suck ATF fluid to the intake plenum and burn it, and bingo burning oil like mad.
3: PCV valve packed solid,and forces engine to leak oil or burn oil. or both. this is a 50k miles service point, skipping this?
4: gas in the oil making it thin and not sneaks past valve stems.
does oil change cure this.>?
now engines.
worn out engines smoke. (burn oil)
as do bad valve guides and seals.
and bad piston rings.
100 years same story, and miles matter. History on engine too.
matters.
Feb 26, 2014 | Geo Metro Cars & Trucks
Why my car 2003 suzuki aerio Sedan turn off when im driving
ill add guesses. stalls. does it restart, easy????
1: lost electrical power to the EFI system.
2: lost fuel pressure
3: lost spark , lost fuel injections.
4: egr leaks, (clean and get it to close, it must close at idle or the engine will stall. 50k mile service point in the manual.
Apr 14, 2013 | 2003 Suzuki Aerio
Sound and wirelss drivers for sharp CS 50K
You can download the audio, wireless and device drivers from the Sharp WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sharp support WEB site :-
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Feb 22, 2012 | Sharp Mebius Computers & Internet
Eror problem bitmap dll
bitmap is a program to view and or edit your photos with the paint program. Try to go in to your file and click on file at the top, then go to save as and change the file type to something other than .btmp. Once you have saved the file as something else try to print again and you should be good to go.
Nov 09, 2010 | HP Office Equipment & Supplies
Verona suzuki 2005 lost power up steep hill lights on just died on me and could only get it in reverse would not go in any other gear problem came out of the blue check engine came on 2 sec before car...
A 5 year old vehicle with only 50k miles? A typical vehicle gets driven 20k a year, possible but doesn't sound right. I would look at transmission and Torque converter inside transmission.
Nov 01, 2010 | 2004 Suzuki Verona
What is perfomed on the 50k servie
If you have the owners manual, that should tell you eveything that needs to be done at 50K.
Jan 09, 2010 | 2004 BMW Z4
232 Plantronics bluetooth manual
flashing purple after you hold it for 3 seconds is discovery mode. blue flashing is active on. hold for 6 seconds to turn off. hold for 2 seconds to turn on.
Jan 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
BlueAnt Bluetooth
hello lilgator
here's your manual from here BlueAnt X3 micro
riz.
Apr 25, 2008 | Blueant Blue Ant 091022 X3 Micro Bluetooth...
Blue Ant
manual can be downloaded from here BlueAnt X3 micro
riz.
Oct 30, 2007 | Blueant Blue Ant 091022 X3 Micro Bluetooth...
Just Wireless Bluetooth Headset Wireless Headset Logo
167 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
