Question about Linksys Wireless-N WRT150N Router
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
I have had intermittent connectivity, last 2 weeks. Then today i lost all connectivuty, talked to BB provider, checked cable modem speed was intermittent, now its fine. Supposedly on 100M/10down, 2 wired and 2 wireless connections, on wired 20/4 down, wireless 5-6/1.5-2 down. .
Posted by p walker on
Bee Santiago
  • 268 Answers
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Posted on Feb 13, 2012
1 Related Answer
eastpole
Tai Viinikka
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
Lg blu-ray bp200 wont connect to wireless network for netflix
Change your network modem/router to WPA-AES only (remove the AES+TKIP setting).
2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
2answers
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Bad connection. dropped internet when connected with mac wired or wireless
I'm not sure but it could be that the particular router has some hardware issues. I bought a Belkin wireless N router a few months back and i had the same problem. It only had a short range and kept cutting off in between. I exchanged it with a new router and voila!. it works fine.
And the other thing i've come to notice. At times having the router under the desk or at a corner might not give off enough to provide a connection within the adjacent room so I've had to place the router in a open and unobstructed place. So much for belkins super signalling.
2answers
Can't connect wirelessly to Belkin Router
have you customized the wireless settings of you router (e.g. ssid, wireless channel, wireless security)? if not, try to change your router's ssid or the wireless channel. it could be that some wireless devices are interfering with your signal.
hope this'll help you.
ciao!
2answers
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Linksys Wireless-N WRT150N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
