Roland Vs2400CD Digital Workstation W/CD Recorder System Logo
Question about Roland Vs2400CD Digital Workstation W/CD Recorder System
Problem getting VS-2480 to connect to internal drive. also to external drive sometimes it works sometimes it won`t Need service manual for mounting new harddrive internally SATA 160 GB Experienced technician, need documentation
Anonymous
    Filmmaker:
    Uploaded 5 video answers.
  • 76 Answers
Hi Karl,
First of all, thank you for purchasing the copy of Roland VS-2480 Service Manual.
Please email me at [email protected], I will send you the copy.
May you and your family have "Prosperous New Year 2012"!
Again, thank you so much!
Mjsazon
Posted on Dec 29, 2011
Spinning wheel death
a new computer? how old is the computer your using and how old is the external hard drive? chances are either the computers pulling every gram of memory out in an attempt to search the hard drive for what you want leaving nothing for you to do other work with. might be upgrade time if its getting on in age.
if the hard drives ageing your going to be better off turning your external drive back into an internal one if you have a tower. you should have room to mount at least 2 drives into the tower. just buy a new hard drive connector and plug it up. the older USB drives work a good bit faster directly connected to the system.
Won't recognize external hd
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
2answers
We want to wacth movie on d laptop,but we need dvd player to put inside,what will we do.
Since you've left out the make/model of the laptop, I'm going to assume it's a NetBook type that does not include a CD/DVD Drive internally, and has no space for one.
With this in mind, the only real choices you have are to watch the movies Streamed to your laptop via a service such as netflix, Copying the movie to a USB drive and viewing it from there, or getting an external DVD drive.
4helpful
3answers
Where can i get a diagram of motherboard connections for acer 2480 laptop
Please follow the diagram of acer standerd motherboard below. From that photo you can solve your problem. 4381470.png
1helpful
2answers
Intel webcam cs430 EXTERNAL VIDEO INPUT SHOWS BLUE SCREEN-NO VID
I had the same problem (blue screen from external cam). I read a few unrelated posts that talked about USB2 vs USB 1 and internal PCI vs external USB hub so thought I'd try a few things. I unplugged my CS430 from an external USB1 (I think - it's a Belkin iPOD synch base with 5 USB ports) hub and plugged it into the front chasis mounted USB 2.0 ports on my Dell Dimension E310 and voila!!! the external cam works and no need to mess around with SP3 etc. Hope this helps.
I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
http://www.rolandus.com/
Jerry G.
Roland VS-2480 DVD Workstation
have problem with vs 2480 anyone fixes  roland vs  2480
2helpful
4answers
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
