SOURCE: My dishwasher is tripping the electric.
Usually time to replace the heating element. The element is sealed inside a metal tube packed with a dry powder to insulate it. If the outer tube leaks (and it only takes a pinhole), the powder gets wet and stops insulating. It only takes a tiny earth leak to take modern trips out. If your dishwasher is one of those where the element is visible in the bottom of the compartment you load the dishes into, replacing it yourself ought to be straightforward. If it's buried in the works, whether you want to tackle it yourself or pay someone else to do it depends on how confident you are. Either way, it shouldn't be catastrophically expensive. A.
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
SOURCE: Asko dishwasher D1876
unblock your filter. unplug all hoses and electrical cords. tip unit up and clean the filter out. should stop all your problems
SOURCE: de 73 tripping house electrics
NEED TO REMOVE AND CHECK WIRING ESPE THE HEATING ELE AND MOTOR WIRES AND LOOK @THE HEATING ELE INSIDE THE ENCLOSURE CLOSE
