Question about Cnet CWR-905 Wireless-N Router
I set my router to factory default. Now I cant reset from my computer. as my computer dont recognise that i have attached router.
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Posted on Dec 29, 2011
Testimonial: "Thanks, saved me lots of time"
SOURCE: How do I factory default settings
The following is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-754, DI-764, DI-774, and DI-784 routers. To perform a reset, please follow steps below: Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults. If you have the European version of this router, this procedure may not work. Please consult the D-Link office near you. D-Link USA does not support the European version.
Posted on Feb 16, 2006
SOURCE: Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
Posted on May 07, 2008
SOURCE: reset to factory default
To reset the router to factory defaults just press and hold the reset button of the router for 30 seconds while the power is ON use a pen or a paperclip to reset the router, then after 30 seconds unplug the power of the router after that the router should be reset already...
Posted on Oct 25, 2008
SOURCE: Hi, I am trying to reset my 2wire 1800HG router in
you have to open internet explorer and type 192.168.1.254. then go to broadband link at the top of the page. hit the advanced settings then you have to re enter all you information like your username, password etc... i hope the helps you if i doesnt let me know.
Posted on May 18, 2009
SOURCE: i forgot my password for my router
Yes, you can (and you have to ) reset your router to factory default if you forgot your password.
Here is how to do it:
Note that your current settings are erased and the base station is restored to the factory default settings!
Now you should be able to connect to the router.
Look at this article and check how to upgrade the firmware to the latest version. (I read about lots of problems with old firmware.)
You should have a manual.If you don't, you can get it here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 12, 2009
