Question about Microsoft Xbox 360 Console
Games Monkey See Monkey Do freezes xbox
When I start Carnival Games in action - "Monkey See Monkey Do" it tries to get downloadable content then the whole console freezes up. I need to reboot it to unfreeze it.
Posted by Oscar Abikhair on
Derek Wager
    New Friend:
Hi, have same issue with this game. It seems that the patch that the xbox downloads is not compatible with newer xboxes. I've set an email to the game maker, but while we wait for them to fix it try the following work around.Clear xbox cache, then remove the internet connection from the xbox, you should now be able to use the game. Do not reconnect the internet until after you finish playing the game and remember to disconnect it each time before playing the game, otherwise you'll download the patch and have to clear the cache again.
Please let me know if this works for you, so that I can inform the game makers and hopefully get a proper solution.
Derek
Posted on Dec 31, 2011
  • Derek Wager Dec 31, 2011
    Derek
My Fallout 3 GOTY keeps freezing and i just bought it any ideas why it isnt working? I freezes where the screen says " Loading extra content
Delete any dlc for the game and redownload it.
If still no luck, make sure that you have downloaded the latest patch.
You also may need to clear the cache data, check out xbox support on how to clear system cache
Jul 23, 2013 | Video Game Consoles & Games
What are the rules?
Place one monkey for each player on the starting square. The other five monkeys for each player start in front of the players.
  • Place one monkey on the bed at the beginning of your turn. University Games recommends the youngest player start, followed by the next youngest, and so on.
  • Flick the spinner to choose randomly the number of spaces to move. Move your monkey that many spaces on the game board.
  • Perform the indicated action on the game board. The actions include bathing, dressing in pajamas, teeth-brushing and going to bed. Act out the actions similar to charades. Once the action is completed, place the corresponding action token in front of you. If you land on an action space you already have a token for, perform the action and the rest of the steps as usual, but do not take a token.
  • Place one monkey on the bed at the end of your turn. If you landed on a space with a picture of monkeys and a number instead of an action, place the number of monkeys indicated on the bed. If you do not have that many monkeys left, put all your monkeys on the bed.
  • Press the red bedpost to end your turn. Pushing the bedpost not only indicates the end of your turn but it also triggers a random action. Occasionally, the bed will shake. If your monkeys fall off, put them back in front of you. If they fall over but do not fall off the bed, set them up right again.
  • As you move around the game board, if you pass the start square, place another monkey on the bed. Repeat steps 2 through 5 until someone has all four action tokens and a minimum of four monkeys on the bed, winning the game.
  • Aug 11, 2012 | University Games Five Little Monkeys Game
    It keeps on saying that im missing downloadable content but im not can anyone help me?
    Try deleting and re-downloading the contents that you have downloaded before, that should help if the DLC (DownLoadable Content) is corrupeted, which can happen if you take out the harddrive etc.
    Apr 29, 2012 | THQ Saints Row 2 for Xbox 360
    My game wont play even though i already redeemed my code what do i do
    Contact Xbox, they are the only ones who can help you with that. Just go to xbox.com/support. Click on games then schroll down and finally click on contact.
    Aug 17, 2017 | Microsoft Xbox 360 Console
    "error downloadable content has changed" can you
    I have the solution time after time I tried playin and got this problem if ur I burnt bout 4 different copie then I burrowed a original installed now back up works fine
    May 10, 2011 | Activision Call of Duty: Black Ops
    My son can not play his downloaded maps. the system says "user content not permitted." how do I raise his age?
    you cant but i believe if you have family settings
    go to family and give him the adult option
    and he will be able to do anything
    Nov 07, 2010 | Microsoft Halo Reach for Xbox 360
    Fallout 3 Freezing Problems???
    Fallout 3 freezing is an unfortunately common problem. A lot of people have reported that clearing the game cache on your 360 will fix it, so that's what I would suggest you try first.
    To do this:
    1. start up your 360, then take out the Fallout 3 game disc.
    2. Hold down the A button on the Player 1 controller
    3. Put Fallout 3 in your 360, then load the game
    If this doesn't fix it, the next thing you could try is to clear the system cache. This will clear the entire cache for your 360, including the automatic updates (though downloaded content, save files, and user dats will be untouched).
    To do this:
    1. Navigate to System > Memory
    2. Highlight the hard disk in the list and press Y
    3. Press X, X, LB, RB, X, X
    If done right, you should see a message asking, "perform system maintenance?" Proceed with this, and it will clear all the cache data out and revert Fallout 3 back to version 1.0 (it should ask you to update once you load the game)
    Hope this helps - I've had my share of frustration with Fallout 3 glitches.
    -Nick F.
    Mar 03, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
    Microsoft Xbox 360 Console Logo
    154 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    James Bradburn
    James Bradburn
    Lee Hodgson
    Lee Hodgson
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
