Computers & Internet Logo
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
I am try to setup my Apple Airport Extreme Router using the DHG535-2 modem but its not working. Any ideas on how I could resolve this issue?
Posted by Tony G on
Waston Ven
    Sergeant:
  • Computers & ... Expert
  • 205 Answers
Our expert technicians always ready for the customer support, they are pick up the phone immediately and provide the solution with taking a few minutes, our service charges very low cost. If the customer can't get the satisfaction of given solution contact our service number which available all technical solution dial 1833 283 8333 for anytime 24*7 hr. Or visit our website for any kind of technical solutions:-
https://servicenumber.org/apple-routers.html
Posted on Sep 25, 2018
Anonymous
  • 247 Answers
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
Posted on Dec 29, 2011
3answers
Connected Airport Extreme wireless router unit to a PC. Airport Utility interface screen shows message: "Airport Utility unable to find Airport wireless devices...." Displays rescan button...
You may contact Windows Customer Service for any kind of help you require. You can also call on Microsoft Windows technical support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5216 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
Airpot Extreme blinks orange when connected, tried all the restarts, waiting, sequenced power downs and ups, still no luck. reckon its a switch from n to g, reckon it might be a dodgy express..anyone got...
British only say dodgy. so bingo for UK?
reckon is only said by us confederates, rebels.lol well the Arris (SB5101U) moldem is first , its LED happy./
SOUNDS LIKE IT IS BAD DO ME, IF MODEM WORKS
AND ROUTER FAILS THEN ROUTERS IS BAD.
But any router made can be not configured at all.
as in hard reset and fails. so reDO alo that. in the Airport router
AirPort extreme
Apple AirPort Extreme 802.11ac User Manual lets read some pages router
wan jack wired to wan jack on modem, check
the AP status LED light
off means no power.
sold amber means AP is process of starting up;.
SOLD GREEN LED: is good
Flashing Amber (orange/) means.
Your AirPort Extreme can't establish a connection to the network or the Internet,
or is encountering a problem. Use AirPort Utility to get information about what
might cause the status light to flash amber. See "If Your AirPort Extreme Status
Light Flashes Amber" on page 18.
the error above amber blink means the AP can not connect to the ARRIS MODEM. so reset it first. reset it by only unpluging AC power from wall for 5min and put back and wait 15min or until modem shows fully connected, to ISP./
the router is last not first. ISP not down today.
if the modem keeps failing call the ISP..
one can wire connect a PC directly tot the modem and test that way
but I will show a page on that now.
https://red-dot-geek.com/connect-pc-modem-ethernet-cable/
now you learned how to test the modem first and then router.
wired
once wired works both modem and router
we play WIFI H3LL all day long, ask. can do but endless causes to fail, in truth.
I need to change the channel settings on my RCA DCM425 cable modem. The problem is my company set up the router and wireless along with an ASA and I do not have any of the original information. How do I...
Cable Modem Troubleshooting RCA DCM425
or
You can change the radio channel on your AirPort Extreme using the AirPort Utility, as follows:
  • Run the AirPort Utility.
  • Select the AirPort Extreme, and then, select Edit.
  • Select the Wireless tab.
  • Select Wireless Options.
  • By default, the channels for both the 2.4 & 5 GHz radios are set to "Automatic." You would first change this to "Manual," and then, select the desired channel.
2answers
The router works and then it doesn't. Now, it doesn't. The modem works with a hard connection but no wireless through the router...the light is orange...it is green for about 1 second after re-set and...
Take the router(s) back to the store from where you bought it/them, along with your computer, and get them to demonstrate how to correctly configure your router and your computer.
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Marvin
Marvin
