Jack it up,pull all brake hardware off of it,take a small sledge hammer hit it a few good times,i mean solid middle hits,and it will pop loose
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Well you have to remove the whole assembly
With a 30mm deep socket , remove the axle nut, do this before jacking the car up...
Then jack the car up and remove the wheel.
Then the tie rod end , brake caliper and lower ball joint.
Remove the cross bolt and brake hose bolt on the strut.
pull the assembly off of the strut.
The you need a press to press the old bearing out after you remove the inner snap ring.
press the new bearing in and install a new outer seal and a new snap ring.
reassemble and if you are using a new hub pull it onto the bearings with the axle nut
rh
