Alarm indicater shows as being set. Alarm doesn't sound, at the time the alarm should sound the display lights up.
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
SOURCE: I have Westclox Atomic Clock,
Greetings.
According to the product manual, press the 'ALARM ON/OFF' button on the back of the clock until the bell symbol and 'Zz' disappear from the display screen. These symbols are between the hour and minute digiits, above the colon ( : ).
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Good luck from Detroit, MI.
SOURCE: how can I reset time zone and alarm on westclox
You can get the manual on the link below.
SOURCE: I have 3 westclox clocks I have lost the
Manual on the link below.
