Question about Symphonic ST427FF TV
NECESITO LOS CODIGOS DE CONTROL REMOTO QUANTUM FX REM 107 PARA UN DVD SYMPHONIC
Posted by VICTOR HUGO DELGADO... on
1 Related Answer
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: tengo un tv de 14
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Posted on Jan 17, 2011
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
Jul 30, 2013 | Televison & Video
Codigo para control remoto quantum fx rem 107 para programar una television marca sylvania
televisor marca symphonic necesito los codigos no los encruentro me puedes ayudar
Apr 10, 2013 | Insignia IS 20" TV040919 TV
Tengo un control remoto universal Quantum fx rem 107 y necesito el codigo para programarlo en un televisor DAEWOO
Tengo un control remoto universal Quantum fx rem 107 y necesito el codigo para programarlo en un televisor magnavox
May 15, 2012 | Televison & Video
CODIGO PARA PROGRAMAR CONTROL REMOTO
¡Hola
Cuatro d?gitos de los c?digos de control remoto universal para TV Insigina son los siguientes
0103 0189 0217 0135
0133 0116 0167 0456 0029
Cinco d?gitos del c?digo remoto universal para TV con RCA Insigina RCR312W modelo de control remoto son los siguientes
11423, 11564, 10171, 11204, 11326, 11517, 11710, 11963, 12002
Entrada directa de c?digos
1.Pulse y mantenga presionado el bot?n SETUP hasta que el indicador rojo permanezca encendido y luego suelte el bot?n SETUP.
2.Pulse y suelte el bot?n del modo deseado (TV, VCR, etc.) El indicador rojo parpadea y luego permanece encendida.
3.Introduzca el c?digo de 4 d?gitos a partir de las tablas de c?digos. Nota: despu?s de una entrada de un c?digo v?lido, el indicador rojo se apaga. De un c?digo no v?lido, el indicador rojo.
4.Con el dispositivo, la prensa de canal hacia arriba. Si el dispositivo responde, sin necesidad de programaci?n adicional es necesario. Nota: Si algunos botones no funcionan el dispositivo, pruebe uno de los otros c?digos para su marca.
M?todo de b?squeda de c?digo
Si despu?s de intentar "Entrada directa de c?digos" el dispositivo no responde, o si su marca no est? en la lista, trate de hacer una b?squeda en la biblioteca de c?digo para el c?digo, siga estos pasos. OK.
Sep 19, 2011 | Insignia IS 20" TV040919 TV
Perdi los codigos de mi control remoto universal GE, 24991, necesito los codigos de cuatro dígitos para televisores marca ony y daewoo. Gracias
Buenas, necesito los c?digos para el programar el control remoto universal a un televisor marca challenger
Sep 23, 2010 | GE RM24948 Remote Control
CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
Jan 28, 2010 | RCA RCU403 Remote Control
Symphonic ST427FF TV Logo
389 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
