Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother mfc 5440cn says no paper fed - Brother MFC-5440CN All-In-One InkJet Printer
5 Related Answers
Mergatroid
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
Anonymous
Unable to clean message. cant see why. Brother's web site is no help.
Posted on Aug 09, 2008
Anonymous
  • 320 Answers
SOURCE: my Brother MFC 465-CN keeps saying "No paper fed"
try cleaning the paper feed roller with isopropal alcahol
Posted on Jan 13, 2009
Anonymous
  • 787 Answers
SOURCE: error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Posted on Oct 28, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
Display shows paper jam, but no paper in machine.
Hi
Turn it off and on.
Try disconnecting the printer from power and from the PC.
Leave it as such for a while before connecting again.
Brother MFC-5440CN message on screen says "unable to change". What is the problem?
That error is usually an indication that there's a paper scrap inside either on the extreme right or left, you have to use a flashlight to see back that far, and sometimes you have to unplug when the carriage is out of the corner to check the far right side.
Brother MFC-5440CN, unable to print
Unable to print is usually a paper jam either in the far right or the far left of the carriage assembly, you need a flashlight to inspect for paper scraps caught at either end of the carriage travel area.
"No paper Fed"
Check the paper cassette and make sure the paper stop is flush up against the paper if it's not push it up against the paper and try again to print.
Replacement paper tray for Brother MFC 5440 cn?
If you go to brothers website you should be able to order a new one from them for about $10 USD plus S+H or so
MFC-5440CN 4X6 PRINT
mabey try using windows, not linux, make sure you have driver and other software on CD.
Brother MFC-5440CN All-In-One InkJet Printer Logo
Ekse
k24674
