I have tried to connect the Turntable to the Amp using RCA Cables, but the sound coming out is not as loud as that of the Tuner, CD and Other Selector Functions. Am i missing sometging out?
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
SOURCE: technics SL-L92 directdrive automatic turntable (needle fixed in lid)
Not sure what could have happened here. Maybe a wire came loose - doubtful, but possible. You will have to open her up to see if there is anything unusual inside. Or, you'll need to take it to a service center for a diagnosis.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
SOURCE: Turntable band
you can go here:
http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=21517
This is the belt for your turntable.
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
You just need a new belt, they're around 20 bucks. Buy them in pairs, or threes. They stretch out about every seven years.
