Van just stopped running after traveling along highway for two hours. Apprears to have spark, will crank over, ignition switch has gear shift locked into park position, and battery has over 12 Volts. Anyway to check fuel pump, crankshaft sensor or ECM for operation without gauges or computer device?
Hello! in 1995 stored trouble codes used the On Board Diagnostic I software (OBDI)..Scanners will not work...The control unit LED can indicate any number of simultaneous component conditions by blinking separate codes, one after another...An instrument panel mounted indicator lamp will light and stay lit. If the lamp is on, or if a system malfunction is suspected even though the lamp is off, it is necessary to inspect the electronic control unit LED display. The LED display is on the ECM (ECU), which is located just below the RH side of the instrument panel. The indicator lamps operate whenever the ignition is On and a DTC is stored in the ECM (ECU) memory.
When an abnormality is detected the ECM (ECU) display blinks. The LED blinks a certain number of times, with the number of blinks indicating the number of the DTC. After the LED blinks a number of times there will be a two second pause and the LED will blink out the number of the next DTC..here are the codes..If there is a code send it to me...If there isn't a code I'll take it from there...guru.saailer
CODE DEFINITION
1 ..Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2.. Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 ...MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4... CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5.. MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
* not 94-95
6... ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7... TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8... TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9... CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
10.. IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12... EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
* invalid code for non-equipped EGR valve vehicles
13... BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14... IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15... Ignition Output Signal missing or defective ignition output signal
16... Fuel Injector System defective circuit or unplugged / defective fuel injector
17... VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19...Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 ..Electrical Load Detector defective circuit or unplugged / defective sensor
21... VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
22... VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23... KS (Knock Sensor) defective circuit or unplugged / defective sensor
30... Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
* invalid code for 1996
31... Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41... Primary Oxygen Sensor - Heater circuit malfunction
43... Fuel Supply System defective or malfunctioning fuel supply system
45... System Too Lean or Too Rich malfunction in the fuel monitoring systems
48... LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54... CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61... Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63... Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65... Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67... Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70... Automatic Transmission malfunction with the automatic transmission controls
71... Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72... Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73... Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74... Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80... Exhaust Gas Recirculation insufficient flow detected
86... ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90... Evaporative Emission Control System leak detected in the fuel tank area
91... Fuel Tank Pressure Sensor low input
92... Evaporative Emission Control System insufficient purge flow
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Testimonial: "Please see above listed additional comment. Thank you!"
The ECM located under the RH side foot rest does not have an LED readout so I cannot determine any stored codes. The check engine light refuses to flash when the blue connectors under the dash are jumpered. To date I have replaced several ignition parts, but the van refuses to run. Plugs fire, but foul out and are wet with fuel. Timing belt and timing appear to be ok when checked.
Hello! Is the problem solved?...I do not see the additional comment you mention...but I'm dying to find out what you found!!!...saailer
Hello! no light on the dash with no response when shorting the connector is beginning to look like a bad ECU...I hope not. There are a couple of test to perform first...Got a meter? Set it to read 5 volts...Using two safety pins push the point into the rear of the in place MAP connector (mounted to throttle body)..Wire colors are Green/white...Yellow/White...and White/Yellow...Push one pin into the Green/White (Ground)....The other into White/Yellow...(+) meter probe to White/Yellow..(-) probe to Green/White...turn on the key...Just to on...Meter must read 2.4 volts...If it does not, move the + probe with pin to the Yellow/White wire...Must read 5 volts...Send a comment...The TPS is also on the throttle body...Wire colors are...Red/Black...Yellow/Blue...and Green /Blue...Use the same technique...(+) probe to Red/Black...(-) probe to Green/Blue...Turn on the key...Must read less than 1 volt (.85)...If not ...Move the (+) probe to the Yellow/Blue wire...Must read 5 volts...If neither results are as required let me know...Saailer
Ok I'll give it a try and let you know. Thank you!
Replaced the distributor and car started right up. Must have been a bad sensor or ICM module. Thanks for all your help.
