Asko D1976 Built-in Dishwasher Logo
Posted on Dec 28, 2011
Dismantle and clean pump on an Asko D1976 dishwasher
Pumps out then fills bottom of washer causing F2 code
5 Related Answers
Anonymous
  • Posted on Aug 17, 2008
SOURCE: Asko Dishwasher F2 Error Flashing
This was very helpful! Only 2 weeks ago I replace the circulation pump on my Asko 1855. Today, when I turned the power on, the F2 error message appeared. I removed the face plates and discovered there was a lot of water in the drip pan. I found the cause to be a small leakage on one of the hose connections. After removing all the water, the water level switch worked properly.
Anonymous
  • 7 Answers
  • Posted on Sep 01, 2009
SOURCE: Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco. b84ee89.jpg8bbfcfc.jpg
Anonymous
  • 725 Answers
  • Posted on Sep 26, 2009
SOURCE: my Asko D1976 dishwasher is not cleaning well, and
I would check you drain it must be clear and it must also raise above the bottom of the sink to keep water from the sink going back into the dishwasher..
Hope it helps if Not let me know more about you problem..I can help
Anonymous
  • 83 Answers
  • Posted on Sep 19, 2010
SOURCE: My Asko D1976 dishwasher is
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Anonymous
  • 43501 Answers
  • Posted on Sep 29, 2010
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
uior24567
1helpful
How do I test the float switch and the pressure switch in an Asko D1976 dishwasher? Getting F2 with no water in the pan or in the machine.
i would assume be n/o.
if have VOM put on OHMS setting. touch ur leads together listen for tone. once verified it works. put on the terminals on switch. and manully switch it, to see if makes or breaks the contact
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 • Dishwashers
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
2answers
2helpful
3answers
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
1helpful
2answers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
2answers
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
